Roaring sound from rear right of car.
Old Jul 27, 2011 | 02:18 PM
exit2600x's Avatar
Icon6 Roaring sound from rear right of car.
I am stumped and so are some of the mechanics I've taken this car to. I came here to see if someone could help.
I have a 2002 Honda Accord. It has a low roaring sound coming from the rear of the car. I've taken it to some mechanics and they say it might be a wheel bearing, but have been too busy to put it on the lift/jack/etc. Got someone to finally look at it, and they say the wheel bearings look fine. They even drove the car with me in it and tried to turn it left and right to see if the sound would change, and it never did.
So apparently they are stumped and so am I. What could this be? Any ideas??
Old Jul 28, 2011 | 04:37 AM
euroraccord's Avatar
Default Re: Roaring sound from rear right of car.
chopped tires?
Old Jul 28, 2011 | 05:02 AM
StreetsideStig's Avatar
I'd check tire/wheel balance.
Old Jul 28, 2011 | 06:20 AM
jordan_rael_420's Avatar
did they actually take of the tire/hub to chk the wheel bearing, i had a 98 accord that made a roaring noise an turned out to be the wheel bearing front right to be exact.
Old Aug 1, 2011 | 06:14 AM
exit2600x's Avatar
Well, finally took it to someone that knows what they are talking about. They got it on the lift, spun each tire individually, and only heard the sound from the right rear. Ended up replacing the rear hub assy. About $270.00 to fix. Would have attempted it myself, but I've never changed one before and they have a warranty on work. Thanks for the replies.
Old Feb 2, 2012 | 09:04 AM
ricebike's Avatar
thanks to this, i ordered one on ebay for $30 shipped (timken 513080 1 year warranty)
now to find the right size socket for the spindle nut (36 mm?) & torque spec (134 ft.lbs.)...
Old Feb 2, 2012 | 07:37 PM
Roader's Avatar
Auto parts stores around here (Autozone, etc.) loan out 36mm sockets, if that's the size you need.
Old Feb 2, 2012 | 07:49 PM
nus_dogg's Avatar
It's definitely a rear wheel bearing.
Turn the car to the left or right to verify, it will get louder as the body leaned to the bad bearing as the whole body weight shifts to one side putting pressure on it.
Old Feb 2, 2012 | 09:56 PM
ricebike's Avatar
yea, i already read some other threads to verify
also noted that spindle nut size; just gotta find out if it's 32 or 36 mm...
Old Feb 2, 2012 | 10:05 PM
btwentyteggy's Avatar
real wheel bearing bro
Old Feb 3, 2012 | 04:21 AM
ricebike's Avatar
thanks for beating the dead horse
Old Feb 4, 2012 | 10:48 AM
ricebike's Avatar
easy job!
the reason mine failed is the past owner didn't torque it down to the right ft.lbs... thus, it wasn't pre-loaded & the outer bearing spun dry first
for future reference:
the back is 32mm spindle nut size (similar to 1 1/4")
torqued to 134 ft.lbs & staked the nut so it won't spin out
the front axle nut is 36mm
mafiaboy01
Honda Civic (2001 - 2005)
Jul 17, 2017 04:31 AM
4everVtec
Mar 19, 2017 09:11 AM
chancekang
Apr 28, 2010 11:12 AM
chefscottd
May 9, 2008 02:46 PM
jdmstreethatch
Aug 11, 2004 05:36 AM
