no afr in dl with crome pro
Old Jul 27, 2011 | 12:04 PM
da_all_day's Avatar
Default no afr in dl with crome pro
i have crome pro and when i load my datalogs to watch later i get all the information as normal. im sending my dls to my friend to look at who also has crome pro and when he loads the dl the afr for his is 0 for the entire thing but all the other information is correct its just the afr that doesnt show up. if anyone could help me out by loading one on my datalogs on their crome pro to see if they get the same problem. also, im using a wideband...
does anyone have an idea on how to fix this?
http://www.mediafire.com/?4gwiq3wakq63nr6
Old Jul 27, 2011 | 02:00 PM
GhostAccord's Avatar
Default Re: no afr in dl with crome pro
Go into File/Settings and click on the tuner logging tab. make sure that your wideband conversion table is set up for the sensor and voltages that you are using.
What wideband O2 are you using?
From what I can see your AFR's seem lean, in the 16-19 range on the few dL's that I looked at. However I'm not sure what WB your using ether.
Old Jul 27, 2011 | 09:14 PM
da_all_day's Avatar
everything on my end is set correctly. im using an aem uego. the issue is that on HIS crome pro the afr's aren't showing up. but as i can see they ARE working for you. so i guess the problem lies somewhere else. ill tell him to make sure that his settings are the same as mine...
Old Jul 29, 2011 | 04:45 PM
da_all_day's Avatar
solved....
he had to set the offset on the tuner logging tab and it just worked
fryguy190
Engine Management and Tuning
Jan 16, 2015 10:50 AM
rico892002
Oct 21, 2012 09:50 PM
got wide
Sep 20, 2008 06:20 AM
1QwIkEf
Jan 21, 2006 05:57 PM
JAW983
Oct 23, 2002 11:55 AM
