Heat wrapping headers good?
Old Jul 27, 2011 | 10:57 AM
doubleoazn03's Avatar
Default Heat wrapping headers good?
I know this has been covered many times, sorry, but I wanted to know from someone first hand who has actually done it. Was there a big gain in doing it? Also my eg came with dc sport headers, are those ceramic? If so, I heard I dont need to wrap them. No, I dont have a high hp motor nor run a turbo either. Just curious
Old Jul 27, 2011 | 11:30 AM
osn grind's Avatar
Default Re: Heat wrapping headers good?
curious on this myself
Old Jul 27, 2011 | 01:03 PM
Anyone?
Old Jul 27, 2011 | 01:11 PM
thenext's Avatar
20% cooler
Prolly no serious gain but it couldn't hurt. It looks pretty tough too.
Old Jul 27, 2011 | 01:51 PM
EL Vap133's Avatar
I have heard that it can rust your header but I am not sure.
Old Jul 27, 2011 | 03:56 PM
I heard it wont rust much if you use special paint or have ceramic headers, I guess ill try it since I got the wrap free
Old Jul 27, 2011 | 04:03 PM
Jdm03's Avatar
Some will cause rust in headers do to moisture accumulating in the fabric and of course if driving through rain it'll absorb it.
Old Jul 27, 2011 | 04:47 PM
visormurp's Avatar
I have no idea if there is any advantage to wrapping a header other than greatly reducing the under the hood temp. I installed an Airmass ceramic header about 6yrs ago on my 95 del sol. After removing the oem heatsheid, lifting the hood in the summer was unbearably hot. Once I wrapped the header, the temp was much, much better. I would guess it was cut in half, but I didn't measure the temp before and after.
Old Jul 27, 2011 | 10:34 PM
goldenchild707's Avatar
Any time you can lower temp in an engine bay is good if you have a sri you could experience a tiny gain as well as dropping temp
Old Jul 27, 2011 | 10:42 PM
98civdx's Avatar
Master Detailer
I have heard this aswell. I have also heard this question a few times but I have never actaully seen any solid proof that it helped with anything.
Although, I have seen turbo guys swearing by wrapping the down pipes.
I would love to see someone with any gains/ or significant temp drops after wrapping the header.
Old Jul 28, 2011 | 03:16 PM
Cap'N Chronic's Avatar
I think it's mainly for turbo setups. Doubt it would make much difference on a n/a car.
Old Jul 28, 2011 | 05:47 PM
jdmpazi's Avatar
This is somewhat true. I actually wrapped my headers on my ek and havent seen much rust accumulation even after racing in the rain a couple of times. I definitely does help when keeping temp down and makes the car feel somewhat better in my opinion..
In regards to the ceramic headers, no i dont think those you need to wrap
Old Jul 28, 2011 | 08:08 PM
Gustav129's Avatar
One thing to consider, heat wraps void most header warranties. I even have my intake wrapped with it. Put a big metal tube in the engine bay and calling it a "Cold Air Intake" . All that metal pipe does is act like a big heat sink, thus heating up the air going into the engine. I've been doing it for a few years, and I just saw a wrap for sale in the latest issue of JEGS. A tech I worked with went to UTI and they did hp tests, and the biggest hp gain they got was putting a piece of cardboard between the intake and the engine compartment, thus insulating the intake.
Old Jul 28, 2011 | 08:18 PM
owneyboy's Avatar
there is an advantage. thats why most aftermarket headers come ceramic coated. ceramic coated headers are like headers with heat wrap. (trap in heat/prevent rust) keep engine bay cooler.ceramic coatings retain heat in the exhaust system increasing exhaust flow.
type B16
Oct 16, 2006 04:38 PM
dezerte
Oct 8, 2006 07:19 AM
H.crx-si
Feb 5, 2004 12:58 PM
SIanara
Oct 30, 2003 09:32 AM
CaNaBiS
Sep 11, 2002 06:45 PM
