Rocker arm assembly seals on d16a6, where to buy?
I'm doing a head-on valve seal replacement, and upon removing the rocker assembly I noticed the rocker arm assembly/spark tube seal for #2 was allowing oil in to the spark tube(I knew oil was getting in there, but couldn't figure out where from because I'm used to B-series motors).
Anyways, I called autozone and they can't find these in anything but their Felpro HS9123PT headgasket set, but I don't want to spend $120+ on that kit only to use those secondary spark tube seals. I don't ever plan on pulling this head, and I'm only using this motor until I get together everything for a B swap.
Does Autozone or Oreilys sell these? If so, wtf are they called? If they're included in the kit, then they must have their own Felpro part number which should mean these stores can order them.
http://www.autozone.com/autozone/par...5107_113309_0_
The gaskets I need are in the bottom-right corner of the pic for that kit, three round gaskets and one that looks like an oddly-shaped 8.
Called Honda and here's what they told me...
91302-PJ7-003 $3.91 x1
91301-PJ7-000 $2.51 x3
They're "CAM HOLDER O-RINGS" according to Honda. The nearest dealer is about 45 minutes away and they do have them in stock, I'll be looking at a hair under $20 shipped and should have them tomorrow or the day after. That's kind of ridiculous for o-rings, AZ or Orlys should be able to get these damn things.since Fel-Pro does make them.
See my post above. They have them, but my car has no rocker assembly or cam in it currently. I'd have to pay $20shipped and hope to get them tomorrow or the day after. I'd much rather have a friend pick them up for me in town at autozone or oreilys for a hell of a lot cheaper.
I went ahead and phoned in the order. They said they'll most likely be able to get it out today, and it should be delivered by tomorrow afternoon. $20shipped is more than I wanted to spend for o-rings.
dismemberment
Feb 18, 2009 02:51 PM
sony224422
Mar 3, 2008 05:44 AM
