92 civic si hatch fuel pump not priming
Old Jul 27, 2011 | 01:43 AM
hatchet_honda's Avatar
Default 92 civic si hatch fuel pump not priming
i recently bought a 92 civic si hatch. i pulled the motor out to be rebuilt. this hatch wasnt running when i got it in fact the prev owner had the motor in pieces. well i cant get the fuel pump to prime when the key is turned. ive replaced the main relay and still nothing. ive jumped the pump directly to the battery and it comes on. ive also jumped pins 5 and 7 on the relay wiring plug and after doing this the pump comes on after the key is turned. ecu is plugged in and works. i had it in another hatch of mine. what else is there to test?
Old Jul 27, 2011 | 07:11 AM
sowellman88011's Avatar
Default Re: 92 civic si hatch fuel pump not priming
maybe a bad/wrong relay since you jumped the pins and it worked
Old Jul 27, 2011 | 08:48 AM
i did notice that the relay makes no clicks when i turn the key but the plug is indeed getting power. so i may have to try a diff relay
Old Jul 27, 2011 | 09:13 AM
sw388's Avatar
Sounds.....like the relay as sowellman88011 stated, along with your no clicks symptom
Old Jul 27, 2011 | 09:45 AM
Former User's Avatar
Does the fuel pump run if you jump 1-7 in the main relay plug?
Old Jul 27, 2011 | 11:11 PM
indeed it does. i tried this relay in a friends 94 civic. no diice..it was dead. plugged his back in and his car started. looks like i need yet another relay
Old Jul 28, 2011 | 03:56 AM
delsolintegra's Avatar
Did you check/clean the ground wires on the thermostat housing?
Old Jul 28, 2011 | 05:15 AM
StreetsideStig's Avatar
Ah, the Honda Main Relay. A bastion of reliability and long life!
At least it's an easy fix.
lapbattleEG
Feb 17, 2012 10:48 AM
Hypermax
17
Aug 13, 2011 04:44 AM
dirtylilhonda
Aug 20, 2008 04:18 PM
blaze_125
Jun 16, 2008 08:15 AM
ls92hatch
Jul 18, 2007 10:44 AM
