Oil Temp Sensor on b16a2?
Do I use this sensor on my b16a2 block, that I'm putting into my 93 integra?
I bought this block bare besides for the crank. I've swapped the other sensors from my b17, but I'm not sure what to do with this one. I'm pretty sure it should go into the port to the left of the oil filter, but I was planning on using that for my catch can.
Can someone tell me what exactly I need to do here?
After doing some more research I found that this sensor is the Oil Temp Fan Switch, which came on 90-93 integras.
I'm not running factory fan wiring so I will not be using this.
99teggsr
Aug 7, 2013 12:34 PM
