IS this a TPS problem ??? Car has a hard time of starting !
Old Oct 2, 2002 | 04:05 PM
NixTEG's Avatar
Default IS this a TPS problem ??? Car has a hard time of starting !
the car just started doing this , it cranks but doesnt start till like 4 turns later !!
BUT when its started it runs fine !!! I just put in new plugs, cap and rotor and i just changed the ECAV valve on the intake !! and it still does it , it sounds like its not getting enough fuel or something !!! IT DOESNT SPIT OUT ANY CODES !!
Old Oct 2, 2002 | 04:14 PM
714phil's Avatar
Default Re: IS this a TPS problem ??? Car has a hard time of starting ! (SlowCivicNick)
could be the starter
Old Oct 2, 2002 | 04:35 PM
IN VTEC's Avatar
Are you waiting long enough for the fuel pump to pressurize the rail? -not saying that that is the problem, but a clogged fuel filter can exacerbate the problem.
If you think the TPS is off, use a multimeter and test the voltage at the TPS harness. Should be .45V.
Edit: Couldn't be the starter if it cranks over quickly and strongly.
[Modified by IN VTEC, 7:36 PM 10/2/2002]
Old Oct 2, 2002 | 08:37 PM
jlicrx's Avatar
probably a bad tw sensor - won't give code but will make it hard to start
Old Oct 3, 2002 | 01:59 AM
NixTEG's Avatar
Default Re: IS this a TPS problem ??? Car has a hard time of starting ! (jlicrx)
TW ?? Temperaature water sensor ?????
Old Oct 3, 2002 | 06:52 AM
letsride's Avatar
Is the gas tank full or close to empty when this happens?
Old Oct 3, 2002 | 02:20 PM
NixTEG's Avatar
Default Re: IS this a TPS problem ??? Car has a hard time of starting ! (letsride)
it does it fill or empty
Old Oct 3, 2002 | 02:24 PM
forthgeneration's Avatar
i accidently had the TPS sensor disconnected on my lude for a few days, and it started normally. i got a cel from that though...
Old Oct 3, 2002 | 03:56 PM
Perfectionist's Avatar
Who made the cap and rotor? Can't go wrong with OEM. Since you had the problem before the change, it probably isn't a factor.
Too many things could be the culprit here. Need more detail to guess. Like... always happens, or only when engine is hot/cold? Is the interrior hot when it happens? ect.
Old Oct 4, 2002 | 04:23 PM
NixTEG's Avatar
Default Re: IS this a TPS problem ??? Car has a hard time of starting ! (Perfectionist)
cap and rotor are both new from Acura,
I JUST noticed something a little weird though, it starts on the first turn WHEN you dont wait for the check to go off BUT when you wait fot the check engine light to go off on the ignition position it takes like three - four turns before it starts !!
Can anyone EXPLAIN or Figure OUT this problem ???
Old Oct 4, 2002 | 07:12 PM
ill phil's Avatar
So you tested for spark and fuel pressure when cranking the engine? You'll need an extra hand but you'll be able to see if you're gettin spark at all on the first couple of cranks and if fuel pressure is dropping. Just a thought.
Old Oct 4, 2002 | 07:56 PM
hoya_10fintec's Avatar
try replacing ur FPR... if ur's is stock/aftermarket but old, replace it... i had the same problem when mine was old... when i replaced it, WOW what a diffrence!!
even acceleration is much better!! don't forget to check ur fuel filter, too!!
Old Oct 5, 2002 | 09:02 PM
visi0n's Avatar
Default Re: IS this a TPS problem ??? Car has a hard time of starting ! (hoya_10fintec)
if your car is older could be the fuel pump...
sdlapeau
Honda Civic (2001 - 2005)
17
Jan 21, 2018 08:04 PM
jadams92
12
May 4, 2013 08:06 PM
OogalyDoogaly
25
May 25, 2008 01:10 PM
Zensa
Nov 3, 2007 09:17 AM
brawl
May 23, 2003 06:31 PM
