Front lower control arm bolt issue 93 EJ1
Old Jul 26, 2011 | 07:59 AM
sk8kingda3rd's Avatar
Default Front lower control arm bolt issue 93 EJ1
Ok so the front inner bushing on the driver side is shot all to hell causing my car to sway when it shifts. I went and bought a new bushing then went to install it. When I tried to take the bolt out, it just kept spinning and spinning, so I looked for the back of it to throw a box end on the other side figuring the nut on the other side was spinning only to find nothing but boxed frame..... My question is was the area that this bolt threads into originally welded to the frame inside of it? Im thinking it was and the weld on the nut/whatever that bolt threads into has broken which is why its just free spinning and not coming out.
Old Jul 26, 2011 | 09:08 AM
kaiba's Avatar
Default Re: Front lower control arm bolt issue 93 EJ1
You are correct. There's a bolt that's weld on the inside. Only way to get to it is to cut it open.
Old Jul 26, 2011 | 09:16 AM
bigred666's Avatar
good luck
Old Jul 26, 2011 | 11:38 AM
Oh goody.....wheres my grinder at......
Old Jul 27, 2011 | 05:54 PM
Coupez6's Avatar
i just bought another frame for cheap...but was a bitch to take everything off. but it gave me a chance to buy new bushings and clean/paint things up..Hope u get it taken care of.
Old Jul 27, 2011 | 07:32 PM
94EG8's Avatar
Seagull Management
a small hole saw works pretty nice in that situation, make 3 holes that all partially overlap to make one slot you can get a wrench in.
Old Dec 17, 2013 | 05:12 PM
chrism1791's Avatar
i really hate to wake up a dead post but i am having the same problem and was wondering about the hole with the rubber plug(on the bottom) of that part of the frame. Could you drill that hole a tad larger and place it up by the hole with a wrench and tighten?
Old Dec 17, 2013 | 05:18 PM
Actually I just borrowed my uncles welder and the hole was just big enough to sneak the nozzle up in there and throw a few beads on it to hold it in place. However hypothetically you could do as 94EG8 said and overlap a few hole saw holes to give you access.
Old Dec 17, 2013 | 07:41 PM
1999ej8's Avatar
I used a magnet off my little snap on pocket screw driver to pick up the nut inside the cross-member after it fell off. Pry against the bolt if it spins in place. Its happened to me on a few cars, small magnet never failed me.
Old Dec 17, 2013 | 07:43 PM
chrism1791's Avatar
I am actually certified in tig mig and stick but do not own a welder ha yeah pretty strange i know but ill just use a bit and make a hole large enough and do that I might tack it later with a stick or mig when I purchase or have access to one, I just need to get this hatch finished.
cletus11
Mar 6, 2011 02:17 AM
YZF
Suspension & Brakes
Aug 12, 2009 06:46 PM
vteck1ck
14
Nov 14, 2008 08:55 PM
Mr.Death
Jan 9, 2007 10:19 AM
LsNer00
Jun 29, 2004 12:09 PM
