'00 Accord intermittent horn issues
Have searched both the archives and web. Have a notion on what the issue may be.
Symptoms:
Horn works fine when car is off
Horn does not work when car is on and steering is straight
Horn works when car is on and there is some steering angle
Brake lights, stop lights, cruise, etc work fine.
Possible problems:
Horn itself - tested and works
Horn relay - not tested but I doubt it
Cable reel/clock spring - could be an issue but I do not see any other problems
Bad ground in steering shaft
Anyone have other ideas? I found several threads but no concrete solutions.
Symptoms:
Possible problems:
Key in on position and running the symptoms are the same. If there any steering angle beyond 10 degrees the horn works. Otherwise if the steering is straight the horn doesn't.
xcathodex
Mar 12, 2003 06:55 PM
1995, 2000, 2002, accord, car, honda, horn, intermitant, intermittant, intermitten, intermittent, issues, problems, repair, steering, straight
