Electrical vss
Old Jul 26, 2011 | 12:26 AM
rigo1224's Avatar
Default Electrical vss
I did a gsr cluster swap in my crx but do not know what write is what on the vss. I know there's a ground, power, and signal. If anyone had any info let me know
Old Jul 28, 2011 | 06:16 AM
1990hondacrx's Avatar
Default Re: Electrical vss
I did a GSR cluster swap into my crx about 2 months ago mainly for boost by gear options in AEM. I found out as doing it that all the pages I found were a little off or wrong on wiring this page shows you the VSS https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/crx-gsr-cluster-swap-2350691/
I ended up making my own wiring diagram and everything worked even the stuff they said wouldn't except for low gas light that wont work. if you have any questions let me know ill open the cluster up and look what wire goes where if you'd like.
french_yogi
Apr 18, 2011 06:24 PM
ALLMOTOR CRX
Feb 13, 2007 05:07 PM
dubb
Aug 8, 2006 02:58 PM
b.d.racing
Mar 15, 2006 01:49 PM
Kataku2K3
Mar 9, 2004 01:03 PM
