Manual Transmission Main Shaft Help.
Ok well in about a week I'm dropping my tranny to replace some bearing's I have some fairly loud bearing noise when I release the clutch and it starts making noise so that tells me it's the main-shaft, the counter shaft, or the diff. I know it's not the throw out bearing on the clutch because it doesn't make noise when the clutch is disengaged and since the main shaft is usually the culprit I'm going to guess it's that.
My question is while I'm in there is there anything I should replace other then the bearings and if so could you show me which parts? Car is an 04 with 90,000 miles on it doesn't leak a drop of oil and shifts smooth as butter just making noise now.
http://www.hondaautomotiveparts.com/...5=MT+MAINSHAFT
HomicidalHatchBack
10
Nov 11, 2006 05:47 PM
Ek9Max
Mar 15, 2005 07:19 PM
d_civic_j
Jul 19, 2004 08:05 AM
