Northwest Alaska, Idaho, Montana, Oregon, Washington, Wyoming
Help passing emissions
Old Jul 25, 2011 | 02:39 PM
EKcpe00's Avatar
Default Help passing emissions
Failed the idle part of the emissions test. I have a boosted d16y8 with stock internals. If anyone's been in this position or knows anything of how to pass please let me know. I can't get the car waived because of Washington state law for modded cars. Thanks guys!
Old Jul 25, 2011 | 09:21 PM
Jdmglenn's Avatar
Default Re: Help passing emissions
like your idle was too low?
Old Jul 26, 2011 | 11:02 AM
1991civicb16's Avatar
Do you have a cat and 02 sensor on the car? Usually if you got a connect at an automotive shop they can just retard your timing..
Old Jul 27, 2011 | 04:37 AM
misterknowbody's Avatar
Did you warm it up before you went in...that is if you have a cat?
Old Jul 27, 2011 | 09:57 AM
iHEARTMYCiViC's Avatar
i know someone that will pass you... but you have to pay extra.
Old Jul 28, 2011 | 04:40 PM
krazyhmongboi's Avatar
how much?
Old Jul 30, 2011 | 10:27 AM
mdrshewrote's Avatar
I had this problem too and I just passed. I don't know about boost cars passing but my N/A did. I had my chipped ECU to stock basemap and had knock sensors off, etc. Drive for 10 miles before going in. I also used those fuel injector cleaner then filled up with good 92 octane. I was in line for not too long but someone told me to keep reving up to 2k-3k RPM and hold til it's your time to keep the cat hot. I also replaced my cat too as well. I didn't have a chance to do an oil change but I would recommend it. If your idle jumps up and down you must clean the IACV so it will resume back to near 500-900rpms on idle, hope this works! good luck.
Old Jul 30, 2011 | 07:54 PM
EKcpe00's Avatar
how much extra??
Old Aug 1, 2011 | 11:46 AM
mechanix619's Avatar
What were the numbers? Were you running a cat?
Old Aug 1, 2011 | 08:05 PM
Originally Posted by krazyhmongboi
how much?
$200.
Old Aug 1, 2011 | 10:05 PM
EKcpe00's Avatar
HC (PPM)
idle limit: 220
idle emissions: 549
that's the part i failed. and yes i'm running a cat.
Old Aug 6, 2011 | 04:58 PM
92_DB2's Avatar
retard the timing works every time.
boostedef123
20
Mar 21, 2012 07:12 AM
cueballsi
Jun 9, 2004 08:16 PM
dingusjt
Aug 16, 2003 08:56 PM
brinks
May 6, 2002 05:51 PM
Go Mifune
Jan 7, 2002 03:06 PM
