Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
TODA Racing Specials! B-Series, K-Series, F-Series!
Old Jul 25, 2011 | 01:38 PM
N1ConceptsC's Avatar
Default TODA Racing Specials! B-Series, K-Series, F-Series!
Hey everyone! We're running a few TODA Racing specials on a few B, K and F-series parts. The promo will be good through the end of the month so make sure to hurry and order soon!
B16A & B18C TODA Adjustable Campulley
TODA Racing campulleys allow precise tuning of camshaft timing. Adjustable campulleys are essential when using TODA camshafts or any non-stock performance camshaft. TODA campulleys are made completely from 7075 aluminum, a higher grade of aluminum than what our competition use. The use of 7075 aluminum allows TODA Racing to offer the strongest and lightest campulley on the market. In addition, our advanced timing degree system makes TODA campulleys the most accurate on the market. For long term durability the timing marks are machined into the metal.
PM for price
B16A & B18C TODA Valvetrain
TODA valve springs allow maximum lift while preventing valve float which can occur under high rpm, high lift conditions. Their specific spring rates prevents damage to TODA camshafts which may occur as a result of using valve springs that are too stiff. Valve springs which are too stiff may also put additional stress on the timing belt.
EGG-SHAPED SECTION springs are used to achieve the high lifts required safely. Lift 12.5mm Max. Variable pitch spring. Compared to conventional designs, The Egg Shape Valve Spring design allows 20% more valve lift with a 15% reduction in weight.
PM for price
TODA B16A & B18C Oil Pump Gear
Made from high spec material and machined by CNC, to give you improved high-speed reliability. Standard Honda oil pumps are made from sintered alloy, this is fine for standard use, but for high performance applications, reliability is questionable.
Two size oil pump gears are available (ø80mm or ø84mm). To determine which size TODA Oil Pump Gear is compatible with your engine, you will need to remove and measure your factory oil pump gear.
PM for price
TODA B16A & B18C Full Face Clutch Kit
TODA clutch kits include a TODA lightweight flywheel, clutch disc, and pressure plate. The entire assembly is balanced on a dynamic balancer to ensure reliable high rpm operation.
The Full Face Sports Clutch Kit is suitable for street/race use.
PM for price
TODA B16A & B18C Timing Belt
An important component that's often overlooked when building high power engines is the timing belt. A broken timing belt can result in bent valves, and in extreme cases, complete engine damage. The TODA timing belt is 200% stronger than the stock timing belt and is designed to protect your engine and improve its performance and consistency. Engine performance is improved by eliminating belt stretch which occurs at high rpms, resulting in inconsistent cam timing and power output. Whether your engine is stock or heavily modified, the TODA High Power timing belt will protect your engine from belt failure.
PM for price
TODA K20 Valvetrain
After extensive testing of the K20A engine, our engineers found that single valve springs made of high grade materials out perform the conventional dual spring design of the factory cylinder head. Allows valve lifts of up to 13.0mm, the material and the coil springs natural frequency have all been optimized. Required for use with TODA K20A camshafts.
PM for price
TODA K20 & K24 Timing Chain Tensioner
An important component that's often overlooked when building high power K20A engines is the Timing Chain & Timing Chain Tensioner. The additional stress placed on the factory K20A Timing Chain Tensioner while employing high-lift camshafts can lead to Tensioner failure, and ultimtely engine damage. TODA's K20A Heavy Duty Chain Tensioner addresses the weak point of the factory tensioner, being the compensator.
PM for price
TODA F20C/F22C Adjustable Cam Pulleys
Accurate valve timing is essential in any high performance or racing application. TODA Racing adjustable campulleys are designed to enable you to extract maximum performance from your F20/22C engine.
Re-designing the F20C cam gears from two to three sections, TODA Racing has been able to keep the original scissors mechanism (noise reduction) and incorporate adjustability into the cam gears.
The adjustment can be carried out to 1 deg of the crank angle.
PM for price
TODA F20C/F22C Heavy Duty Chain Tensioner
To maintain correct tension and to overcome the oil pressure auto tensioner's weak-point, preventing the valve timing slipping under engine braking. Work with heads that have up 1mm shaved off the deck face. Recommend to use with TODA Heavy Duty Chain.
PM for price
Toda F20C/F22C Exhaust Manifold
TODA Racing currently offers 2 versions of the S2000 exhaust manifold. The Standard version is designed to improve power through out the entire powerband, with a focus on high-end power. This version is recommended for competition use where the engine operates mainly in the high rpm range.
A new version dubbed the "Torquie-kun" is designed to boost midrange torque and power even further, with only a minor loss in high-end power compared to the Standard TODA exhaust manifold. Both versions are constructed entirely from high grade stainless steel for long term durability and lightweight construction.
PM for price
Old Jul 26, 2011 | 08:20 AM
Default Re: TODA Racing Specials! B-Series, K-Series, F-Series!
Bump! Specials are only good through the end of the month! After that, pricing will increase by over 10%! Get your orders in today!
Old Jul 27, 2011 | 09:37 AM
Bump!
Old Jul 27, 2011 | 01:49 PM
Afternoon Bump!
Old Jul 28, 2011 | 08:00 AM
Bump!!
Old Jul 28, 2011 | 02:30 PM
Only a few more days! Get your orders in!
Old Aug 8, 2011 | 01:24 PM
6SPD_EK's Avatar
I'm interested in:
toda k20a exhaust cam gear
toda k20a valve springs
toda k20a timing chain
toda k20a balancer/oil chain
toda k24 timing chain
toda k24 balancer/pump chain
let me know
Old Apr 4, 2012 | 09:29 AM
alex eg hatch's Avatar
I am interested in price for toda timing chain for b18c. Also. Am gears and oil pump gears
Thanks Alex
FlewByU352
86
Oct 25, 2011 01:55 PM
holset b18c
Nov 14, 2009 07:10 PM
Turbo R
Aug 15, 2002 07:36 PM
93B18
Jun 20, 2001 11:00 AM
