oil pressure switch trouble
Old Jul 24, 2011 | 12:29 PM
gwarbmx's Avatar
Default oil pressure switch trouble
i have a a6 wire harness and a y8 swap. my question is where do you or how do you hook it up? for now i am running a pm6 ecu. i have a p28 and jumper but i have to tune it. so i just wanna know if i can use the a6 harness or do i need a y8 harness?
Old Jul 24, 2011 | 06:26 PM
D16SiHatch's Avatar
Default Re: oil pressure switch trouble
You always keep the stock harness, short of k/j swaps. Not sure what you are trying to hook up because neither an a6 or y8 has an oil pressure switch. There is a 1 wire oil pressure sending unit however.. and is this a stock y8 you are using? if so their is really no need for a tune, the z6 and y8 are nearly identical.
UltimateAmature
Mar 21, 2012 05:01 PM
SOLEpassion
Mar 10, 2010 04:26 PM
spikeddrummer
May 20, 2003 11:32 AM
