Can a cracked header cause idling issues?
Old Jul 24, 2011 | 07:59 AM
amej8's Avatar
Default Can a cracked header cause idling issues?
The car is a 97 dx (stock y7 with 200k) and I can't come to a solution here... There is no check engine light btw. We tried spraying all the vacuum lines with a bottle of water and a tiny bit of soap with the car on at operating temp to see if any bubbles would form. Nothing. We had to take off the throttle body and IACV anyways to get rid of a sticky gas pedal, hooked everything back up, so nothing there. But the car however does have a good size crack, about 2" long, very thin, between the middle runners where they all meet above the cat. Can this cause a bouncy idle? The car doesn't have a tach so I can't say the range it's bouncing between but I can say it only does it in park and neutral, not in drive or any other gear.
Any input? Thanks in advance.
Old Jul 24, 2011 | 08:06 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Can a cracked header cause idling issues?
Yes. Replace it.
Old Jul 24, 2011 | 08:14 AM
that_boy_sammy's Avatar
A cracked header would only cause back fire's from the mixtures of o2 and gasoline fumes. Let your car warm up then turn it off. Unplug your iacv and turn your car back on and see if the idle went down. If so drain your coolant, clean iacv, make sure the gasket to your throttle body is not letting in any air, refill coolant, burp coolant.
Old Jul 24, 2011 | 08:21 AM
amej8's Avatar
We cleaned the IACV, TB, gasket, and mating surfaces. Everything appears to be nice and tight and isn't having any leaks.
It's my friends girlfriends car and he plans on buying a new header for it at some point. He just wants to get it running a little better to be able to pass inspection (just got it, temporary inspection).
Thanks guys.
Old Jul 24, 2011 | 10:52 AM
motegicivic's Avatar
I thought 96 and and up did not have an IACV?
Old Jul 25, 2011 | 05:43 AM
amej8's Avatar
I believe it's: 96 and up have the IACV but not FITV.
Old Jul 25, 2011 | 07:00 AM
k20a2delslo's Avatar
Yes, All engines need some backpressure to operate properly the crack will significantly reduce it.
Old Jul 25, 2011 | 08:25 AM
judgementday's Avatar
I had a similar problem with just a break in my test pipe. caused my idle to be all over the place but mostly higher. If you have played with the throttle cable and timing then ya back pressure is good deal.
Granulatedsugar
Apr 15, 2016 01:19 PM
alupso
Mar 4, 2008 02:43 AM
drifter_for_life06
Jul 12, 2005 07:16 PM
B20poweredDA
Nov 18, 2004 10:02 PM
chirp2hrd
19
Sep 19, 2002 09:24 PM
