civic bogging,jerking,slowing down?
Old Jul 23, 2011 | 07:25 PM
jdmdreamz414's Avatar
Icon2 civic bogging,jerking,slowing down?
have a 97 civic with 96 ls swap..car is bogging..slowing down on acceleration? checked timing,map,changed tps,ignition coil,rotor,cap,wires..idk why its doing this..car has no cel's... can anyone point me in the right direction..the guy looks like he used an ond2 single cam harness
Old Jul 23, 2011 | 07:36 PM
White_EK_Hatch's Avatar
Default Re: civic bogging,jerking,slowing down?
Have you done a compression check?
Old Jul 24, 2011 | 08:35 AM
Yes 150 across the board
Old Jul 24, 2011 | 09:05 AM
97sohc_d00d's Avatar
i have the same problem in my 97(its a sohc tho) i seem to think its a fuel issue...check your fuel filter...mine is dirty, just havent replaced it yet
Old Jul 29, 2011 | 09:05 AM
just replaced the fuel filter and my issues have went away...worth a shot
Old Jul 29, 2011 | 10:36 AM
Former User's Avatar
OBD2 or OBD1 ECU? Does the CEL work?
Old Aug 6, 2011 | 01:27 PM
Obd2 and CSL does work cause I have pulled codes from it before..there are no codes for it..update I just unplugged the tps sensor and it doesn't do it no more..changed the sensor before too..I'm guessing the wiring is the problem
acmeotally
37
Jul 15, 2015 02:47 PM
Fopple
Mar 2, 2010 02:43 PM
drycreekgsr
Aug 25, 2006 08:47 PM
