advice?
Old Jul 23, 2011 | 02:29 PM
sh!ft's Avatar
Who the fack changed my title?!
Default advice?
ok, so, im making a custom gauge setup for my car, and im wanting to construct the actual plate that the gauges will sit in out of metal. any advice or suggestions on what thickness of metal to use? thinking alum or regular steel.
Old Jul 23, 2011 | 03:48 PM
SovXietday's Avatar
Default Re: advice?
The thickness is up to you. Thinner will be easier to make the cuts and drill the holes and also to make any bends that you need. Thicker will be a little more sturdy and a little bit easier to mount to.
I like aluminum for this kind of thing personally. It's easier to cut and drill, and it's lighter. Just be careful, as the finish is EXTREMELY easy to marr. 1/16 (.065) is a good thickness for me, but you can go pretty thin without issue (I think I used 22 gauge galvanized sheet for mine).
Old Jul 23, 2011 | 05:12 PM
sh!ft's Avatar
Default Re: advice?
thats what im thinking about doing along with a supporting bracket. where do you think this type of metal can be had at? lowes/homodepot?
Old Jul 23, 2011 | 06:00 PM
redboost10's Avatar
Default Re: advice?
i used 1/8" al plate...then i ended up using that as a mold to make a carbon fiber one.
Old Jul 23, 2011 | 06:32 PM
SovXietday's Avatar
Default Re: advice?
I picked up the thin sheet at lowes, but they don't really have any plate. I usually order anything plate online through one of the sponsors on here.
Old Jul 23, 2011 | 06:50 PM
sh!ft's Avatar
Default Re: advice?
dont let the cat out the bag yet!!!
crx12
15
Apr 20, 2004 06:13 AM
crx12
Apr 6, 2004 12:59 PM
dingusjt
Sep 6, 2003 10:20 PM
