which rockford fosgate amp to go with?
Old Oct 2, 2002 | 01:54 PM
ku09's Avatar
Default which rockford fosgate amp to go with?
im getting 2 12" JL audio 12w3 D4's. which amp would i need to make the 250W RMS on each of them?
Old Oct 2, 2002 | 02:11 PM
o_Rage_o's Avatar
Default Re: which rockford fosgate amp to go with? (ku09)
A Power BD500.1 at 2ohm will rock those subs with around 600 clean watts.
just make sure to fuse the amp properly and keep it well ventilated.
Plus it has 24db butterworths built in
-Rage
Old Oct 2, 2002 | 09:51 PM
typerudel's Avatar
Default Re: which rockford fosgate amp to go with? (o_Rage_o)
i would actually run the 800.1. those subs can take much more power than they are rated at. ive seen 2 of those with somewhere 1000 watts hit 149db's
Old Oct 2, 2002 | 10:21 PM
RegRedTeg's Avatar
Im not a fan of fosgate or JL audio but if you only want 250watts to each sub just get the JL 500/1. If you want some serious wattage get a us amp, or a bmf 1000d would do those subs nicely and wire that bad boy to 1 ohm mono since you have dual 4s.
Old Oct 7, 2002 | 09:20 PM
incubus's Avatar
Default Re: which rockford fosgate amp to go with? (RegRedTeg)
1 ohm mono- not a good idea, try to keep it at 4 ohms. that is best for your subs and amp. I'd say a rf 500.1 or 500.2 also. wire the subs in a parallel-series-parallel config. this will keep them at 4 ohms.
Old Oct 7, 2002 | 09:40 PM
ku09's Avatar
Default Re: which rockford fosgate amp to go with? (incubus)
yea i want to keep it at 4 ohms but if i get the 500.2, its rated at 250W @ 2 ohms and 125W @ 4 ohms. Can i get it to 250W @ 4 ohms? or do i need to get a rf 500.4 and bridge it to make the 250W?
Old Oct 7, 2002 | 09:50 PM
RegRedTeg's Avatar
why would wiring to 1 ohm be a bad idea? I can see doin 4 ohm for sound qualit setups but when you compete most people never do 4 ohm either .5, 1 or 2ohm mono. Espeically when most high quality amps are low ohms.
Old Oct 7, 2002 | 09:51 PM
RegRedTeg's Avatar
alright if you want to get a 4ohm amp just get a precision power amp.
Old Oct 7, 2002 | 10:14 PM
nsxxtreme's Avatar
????????What??????????????/
What does sound quality have to do with it. I seriously doubt you will hear the difference in sound quality.
The reason people who compete wire their subs this way is to stay in a lower power class. But there are also running amps designed for this. Running this lower impedence will heat the amp up a lot Faster!!
Old Oct 8, 2002 | 08:21 AM
RegRedTeg's Avatar
Default Re: which rockford fosgate amp to go with? (nsxxtreme)
You will not hear the difference but if you look at any sq setup its configured to 4 ohm. 4 ohm is less stress on the amp. Also the whole running at 1 ohm to be in a lower power class, that really isent right because rules have changed. In dbdrags it has nothing to do with amount of power. Ive ran us amps, ppi, crossifre, earthquake, and have always ran them at 1 ohm mono or 2 ohm and never had a problem as long as you have the right voltage.
Old Oct 8, 2002 | 11:40 AM
ku09's Avatar
can someone please help me on my question. thanks
Old Oct 8, 2002 | 02:49 PM
incubus's Avatar
the rockford 500.2 are rated at 500x1 rms and 125x2 rms. the key to rockford two channel amps is bridging, you said you had 2 dual 4ohm voice coil subs wire them in parallel-series-parallel config. this will keep your subs in a 4 ohm load. meaning parallel the two voice coils coming from each sub into one + lead and one - lead. then take those leads and series them with the other subs single leads . so you will take the + from the first sub and put it in the positive terminal, take the negative from that sub and wire it to the positive from the other sub, then take the negative from that sub and put it in the negative terminal in the amp.
then your subs will have 250w rms each (125 per voice coil).
[Modified by incubus, 12:40 PM 10/9/2002]
Old Oct 8, 2002 | 06:27 PM
ku09's Avatar
thx incubus, as you can see, im new to all this. if i have any more questions, ill be sure to ask you for help. thx again
pityocamptes
Audio / Security / Video
Dec 4, 2017 03:01 AM
ilikeric3
30
Sep 2, 2006 02:21 PM
Jonathan_ED3
11
Jul 9, 2003 10:33 AM
redteg1
Apr 9, 2002 08:46 PM
woodog
Dec 17, 2001 11:08 PM
