89 honda with mini me swap
Old Jul 22, 2011 | 06:31 PM
Optimusfps's Avatar
Default 89 honda with mini me swap
I have a 89 civic lx with a 93 mini me swap.
the camshaft froze up and i bought a new head and rebuilt the lower end. At first it wouldnt start so i replaced the main relay and its fine, but now it wont idle at all and im not sure if im pluggin in the wrong connector to the IAC or if the IAC is bad. The person who did the swap before me used the stock d15b2 engine harness and distributor and wired in the connectors for the intake and injectors. This thing is all messed up and im not sure where to start.
PLEASE HELP!!!!!!
Old Jul 22, 2011 | 07:47 PM
19[tbus]90's Avatar
Default Re: 89 honda with mini me swap
pics?
Old Jul 23, 2011 | 12:38 PM
turbohatchBnuts's Avatar
what ecu are you using? any cel codes coming on?
Old Jul 23, 2011 | 03:32 PM
nonvtecD's Avatar
Was it already a mini me when you bought it? If so you need to check your timing, both cam and ignition, and check for vacuum leaks. Won't idle at all? is it rough? High? Hard to start?
Old Jul 23, 2011 | 05:25 PM
Optimusfps's Avatar
Is was a mini me non-vtec and I rebuilt the whole engine and put a vtec head on it. I timed it before I put the engine inand it runs good it just won't idle. To get it to start I have to push the accelerator so I think it's the iac but not sure.
Old Jul 23, 2011 | 06:35 PM
nonvtecD's Avatar
Gaping vacuum leak?
Old Jul 24, 2011 | 08:30 AM
Optimusfps's Avatar
if it was a vacuum leak i would think that it would still idle just really high
Old Jul 25, 2011 | 05:37 PM
could be tps sensor. my turbo ef idled high really bad and i changed my tps with new blox one and adjusted it, idles alot smoother now.
Old Jul 25, 2011 | 05:38 PM
also check to see if your ecu is getting any cel codes.
92 CIVIC HATCH VX
Dec 25, 2015 06:01 PM
CRX_nut
11
Jan 21, 2010 10:32 AM
itzyaboyzeem03
Sep 15, 2009 01:51 AM
memorybox
10
Nov 19, 2006 01:42 PM
Touge Tuning
Apr 26, 2006 11:51 AM
