Wheel Spacers
Old Jul 22, 2011 | 12:02 PM
toshko321's Avatar
Default Wheel Spacers
Where can i find some cheap wheel spacers for my 1999 sedan. Preferably 10mm rear front 5mm or 8mm. Link me some goodies if you know of any sites or anything like that. Trying to get the cheapest spacers out there but idk if they are good or not.. Let me know guys
trying to space them out: some pics
Old Jul 22, 2011 | 12:11 PM
Red_Army's Avatar
Default Re: Wheel Spacers
egays.
Old Jul 22, 2011 | 12:14 PM
toshko321's Avatar
do the ebay Kics universal spacers work well? and would i need extended lugs if i get 10mm for the rear?
Old Jul 22, 2011 | 12:15 PM
Samsung's Avatar
You can run 10mm without extended studs, but it's better safe than sorry. I'm using Ichiba 15mm up front and 10mm in back. Both with extended studs.
Just get a package that comes with extended studs.
Old Jul 22, 2011 | 12:16 PM
toshko321's Avatar
where can i get extended studs at?
i cant really afford the Ichibas, so i was wondering if the ebay Kics are fine?
Old Jul 22, 2011 | 12:17 PM
toshko321's Avatar
for example: http://cgi.ebay.com/ebaymotors/KICS-...#ht_3882wt_939
alphalanos's Avatar
I also have Ichibas with pressed in studs. They are good. If the Kics on ebay are real ones, then I would say they are ok.
Old Jul 22, 2011 | 12:18 PM
Samsung's Avatar
Cheap spacers themselves are fine, but don't cheap out on extended studs.
There's tons of online shop that sell extended studs. Google is your friend.
I ordered my stuff from ProTuningLab
Old Jul 22, 2011 | 12:19 PM
toshko321's Avatar
damn spacers are too expensiveeee
Old Jul 22, 2011 | 12:20 PM
alphalanos's Avatar
You really should get ones that have centering rings, those are like 76mm while the civic hub is 56.1. thats almost a half inch gap all around your hub, makes for a high possibility that your wheels will be off center.
Btw you can get extended studs from ARP
Old Jul 22, 2011 | 12:21 PM
toshko321's Avatar
so you think that if i get some cheap ebay spacers and get good studs it should do the job?
Old Jul 22, 2011 | 12:24 PM
toshko321's Avatar
would these work? http://www.lightningmotorsports.com/...1/i-61595.aspx
Old Jul 22, 2011 | 12:26 PM
Samsung's Avatar
Yes. Take what alpha said seriously about the centering rings.
Old Jul 22, 2011 | 12:44 PM
toshko321's Avatar
what centering rings are u talking about... send me some links on what i need lol
Old Jul 22, 2011 | 01:02 PM
Samsung's Avatar
http://www.advancespeedshop.com/ichi...0-p-15713.html
Look at the ring in the middle that sticks out. That helps center your wheel.
Old Jul 22, 2011 | 08:33 PM
toshko321's Avatar
hey can you guys please tell me the exact size lug pattern and size that i need for my 99 civic. all i know is that they are 4x100 and i know which thickness spacer i want. thanks!
Old Jul 24, 2011 | 06:39 AM
Sean @ ESG's Avatar
Inline Four has cheap spacers. I've been running two stacked 5mm's up front, and 3mm's in the rear with no problems so far.
They are universal so just order what thickness you want.
B20vCRX
Nov 6, 2018 07:45 AM
uscivicmc
Jan 17, 2012 10:07 PM
dc5RickK20
Jan 11, 2011 09:38 AM
Kenzo206
10
Mar 23, 2009 10:05 PM
iheartintegras
Jan 26, 2008 09:01 PM
