del sol - vent blower motor not working
i have a 94 del sol when i got it the ac worked fine but was disconnected at the fan.and now there is no air coming thru the vents on any setting.i turn the ac on and the fan turns on but still no air thru vents hot or cold.unless im in motion of course hot air creeps in.i bought a blower motor relay as the cheapest suggest ive heard but i don even know where it goes.
if anyone has any idea on how i can get some cold air in my car please its freakishly hot out an i literally cant drive untill night time and even then its still almost unbarable
yes i do mean condenser fan.so there IS a third fan?i went thru and checked fuses under hood and in dash but where exactly are these fuses to be sure?and thank you for your feedback
I'm really confused because I expected you to say the blower doesn't work because you said that no air is coming out of the vents.
So the only problem is that the condenser fan doesn't work?
oh ok i think i am in the right direction now since i only seen two fans i was lost.the radiator fan and condenser fan both work fine its the blower fan im probably having problems with.cause thats exactly the only problem no flow in the cabin (lol cockpit).fuse and/or relay placement?
i checked,fuse 13 is fine.smelled like a blown fuse under my hood in that fuse box but i checked all the fuses they were all fine and none of the relays smelt burnt but i for sure smelled something,thinkin it was the blower i took my glove box out smellin round up there and still smelled nothin but its also 2am so what do i kno im goin to bed
MoneyMillz516
Mar 7, 2014 10:05 AM
Russ713
Jul 9, 2003 10:27 AM
94, ac, ai, air, blower, conditioner, conditioning, del, fan, honda, light, sol, troubleshooting, turning, working
