engine code 71,72,72,74 plz help!
Old Jul 22, 2011 | 09:21 AM
got-vtec?'s Avatar
Default engine code 71,72,72,74 plz help!
My car started sputtering the other day along with a check engine light. pulled the codes, 71,72,73,74. each cylinder is misfiring. I'm trying to narrow down the reasons as to why. Im assuming the distributor is bad. It starts like ****, it takes maybe more than 6 seconds to start, and when it does i can smell gasoline pretty bad. Is that a sign its running rich? Im assuming its running rich because its getting insufficient spark and thats also causing it to sputter?
I'm not that great on diagnosing, so any help is much needed/appreciated
Old Jul 22, 2011 | 11:46 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: engine code 71,72,72,74 plz help!
Whens the last time you've done a full tune up: cap, rotor, plugs and wires? Check those first if you haven't. Then check here to diagnose parts in the distributor:
http://techauto.awardspace.com/ignition.html
Old Jul 22, 2011 | 01:59 PM
got-vtec?'s Avatar
cap and plugs just a few months ago. wires are under two years old. the problem shouldnt be there
Old Jul 23, 2011 | 05:07 AM
grumblemarc's Avatar
The Grumpiest
What about the rotor? I think the rotor was mentioned in post #2 as well.
Old Jul 23, 2011 | 11:52 AM
got-vtec?'s Avatar
no not the rotor. i replaced my distributor with another used one yesterday. the sputtering and misfiring is gone, but when i start the engine it still takes longer than normal. and when it does start, the rpms jolt from 1,000 and then settles at 1,500rpm
Old Jul 23, 2011 | 02:26 PM
The Grumpiest
Check the timing?
axis11
12
Jun 9, 2013 01:16 PM
darrinirox
11
Nov 10, 2012 05:07 PM
IlsCrx
Mar 28, 2006 05:50 PM
AzntaggeR
Feb 25, 2004 12:02 AM
Jon5240
Jan 19, 2004 10:06 PM
