what tuning system is right for me?
Old Jul 22, 2011 | 08:42 AM
xxliljonxx1's Avatar
Default what tuning system is right for me?
hey guys, im a little bit of a noob when it comes to tuning but ive recently bought a turbonetics t3/t4 turbo kit. I plan on using this on my 2001 acura integra ls, boosting at about 8-10 psi with 440cc injectors. The only issue is money is running low and im going to need a professional tune. I was wondering what the cheapest but still efficient and reliable tuning system for me (ie hondata, emanage, crome, etc...) Also, but much less important, how much hp should i expect out of this setup?
Old Jul 22, 2011 | 09:49 AM
mtber's Avatar
Default Re: what tuning system is right for me?
The most cost effective tuning solution that will work well would be using an obd2b to obd1 ecu jumper with a chipped/socketed obd1 ecu.
For more information on this subject, review http://www.phearable.net/tech/efibeginnerguide.html
Old Jul 22, 2011 | 12:53 PM
likwidchz's Avatar
do yourself a favor and never buy an SAFC
Old Jul 22, 2011 | 02:31 PM
What's an SAFC? And why shouldn't I buy it? Lol
Old Jul 22, 2011 | 03:48 PM
mtber's Avatar
SAFC is a piggyback. If you review the link I provided above, it explains why not to use one.
Old Jul 22, 2011 | 03:52 PM
Oh okay, so that's like emanage and the s200 right?
Old Jul 22, 2011 | 06:04 PM
mtber's Avatar
No, s200 uses the factory ecu code, it is not a piggyback.
emanage is a piggyback.
Read http://www.phearable.net/tech/efibeginnerguide.html
Old Jul 23, 2011 | 09:36 AM
Okay, thanks for all the help. I'm pretty sure I'm just gonna chip an obd1 ecu and get it tuned. But what should I use ( ie Chrome , uberdata, ectune, etc ) or should I let that be up to the tuner?
Old Jul 23, 2011 | 09:47 AM
GhostAccord's Avatar
You should leave that up to the tuner. However, don't always go with the most expensive one just because they say. Find out the range of tuning that they can do and ask for one that suits your build and falls within your budget.
Old Jul 23, 2011 | 10:14 AM
mtber's Avatar
If you are having the car tuned by a tuner using a standard chipped ecu I would suggest you use ectune, neptune or hondata before anything else.
To find a local tuner in your area check:
1. http://www.hrtuning.com
2. http://www.ectune.com
3. http://www.hondata.com
Good luck!
kiryl501
Engine Management and Tuning
Sep 16, 2018 10:59 AM
V-Nonyak
Mar 5, 2012 01:47 PM
Nj_Sol PWR
Mar 2, 2009 04:38 PM
siblue_gzer
Nov 1, 2006 08:13 PM
BlackThorN
Aug 3, 2003 11:32 AM
