ls swap questions?
Correction - You WILL NOT need an adjustable fuel pressure regulator or gauge for ANY swap. Even if the car originally had DPFI... The only time that is needed is when you go power adder (boost/ nitrous) and even then you can just up injector size without turning up fuel pressure (to a point obviously).
