Electrical Guru's, need your help ASAP!
Old Oct 2, 2002 | 01:04 PM
migs's Avatar
Default Electrical Guru's, need your help ASAP!
My friends 2002 Civic radio no longer works. Along with this problem, keyless entry doesnt work.
Also, the interior doesnt chime when you have the keys inside the ignition. What could this be? fuse or relay?
Thanks in advance.
--Migs
Old Oct 2, 2002 | 01:05 PM
WAFFLES's Avatar
Default Re: Electrical Guru's, need your help ASAP! (Migs)
sounds like its fucked.
Old Oct 2, 2002 | 01:16 PM
migs's Avatar
Default Re: Electrical Guru's, need your help ASAP! (WAFFLES)
LOL, Blake your'e wack dude, I need help and you have nothing but negativity. Booo!!
BTW, Im in Dallas now for a few months.
Old Oct 2, 2002 | 01:23 PM
bryan305's Avatar
DID you check the fuses? could just be a bad common ground...had one that was messing with my headlights and turn signals..
Old Oct 2, 2002 | 01:25 PM
WAFFLES's Avatar
Default Re: Electrical Guru's, need your help ASAP! (bryan305)
hahaha....
Boo yourself buddy!!!! That's the BOOOO face!!!
Old Oct 2, 2002 | 01:36 PM
B_CRUZ!'s Avatar
my guess would be the fuse, but why it would go bad is beyond me.
byron
Old Oct 2, 2002 | 01:47 PM
ejprimo's Avatar
Default Re: Electrical Guru's, need your help ASAP! (B_Cruz)
isnt it under warranty?
Old Oct 2, 2002 | 01:49 PM
ITACivic's Avatar
Default Re: Electrical Guru's, need your help ASAP! (ejprimo)
Back in my day as a Circuit Shitty installer I found that the door lock module is located in the radio chassis. Might be the same for the 2002 modles. Check the fuse for the radio. The chime is dependant on the dome light so check that fuse out also. If the fuses are good, then head off to the dealer.
I rarely visit this forum, glad I did today. I hope I helped you.
[Modified by ITACivic, 2:51 PM 10/2/2002]
Old Oct 2, 2002 | 07:15 PM
migs's Avatar
Default Re: Electrical Guru's, need your help ASAP! (ITACivic)
It ended up being a fuse. Its under warranty but the dealership couldnt get it in til Monday.
We just overlooked a fuse
Old Oct 2, 2002 | 07:23 PM
Civicexb16a2's Avatar
what'd you do that did this?......
Old Oct 5, 2002 | 07:08 PM
PnX-R's Avatar
It ended up to be a fuse huh?.. Well, let me tell you something.. If it was a blown fuse. I bet you it'll happen again. You want to know why?.. It's because Grounded Circuits blow fuses. And if you don't find and fix them, it's gonna happen again. And here's another thing. There's no such thing as a "bad" ground. I can corrodded ground, or even a loose ground. But I can't tell if it's bad. Think about it.. That goes for everyone..
Brycen
Dec 4, 2004 05:46 PM
compwc18
17
Mar 23, 2004 12:22 PM
crx_kid
Oct 15, 2003 03:56 PM
AH Tow EX
Jan 15, 2003 04:48 PM
