What size slick for my set up... Please
Old Oct 2, 2002 | 12:56 PM
MisterB's Avatar
Default What size slick for my set up... Please
ya i know this has been beat to death and yes i searched but i need help choosing a size... i have a 91 hatchback with a b16a, ctr cams, ctr springs and retainers, sk2 cam gears, ctr pistons, vafc, itr intake manifold, i/h/e, chipped ecu,
i was thinking maybe 22x8x13
or maybe 22x8x15
or if you all have any other suggestions... thanks
Old Oct 2, 2002 | 01:02 PM
hybridreams's Avatar
Default Re: What size slick for my set up... Please (cl4show)
Me too
Old Oct 2, 2002 | 01:48 PM
Gmedalion's Avatar
Default Re: What size slick for my set up... Please (hybridreams)
22x8x13 will be good for ur setup....this size is really good up to almost any pwr, as this size has lead Mike Laskey to a 9 second pass
Old Oct 2, 2002 | 03:58 PM
skunked's Avatar
I would recomend 20" slicks. The reason being is that my friend has a similar setup with 185hp 121tq in a 91 hatch. He was running 13.2 all day long on the 20". We went to Sears point recently and he ran 13.3 & 13.4 with a little more HP than the 13.2 runs on 22" slicks this time (also better track conditions). He also has NOS and run's a 12.6 on those 20" slicks. You need at least 135 ft lbs of tq to run those 22" slicks unless you have a 4.785 or ATS final drive then I would run the 22" slicks. Hope the info helps.
13.1 @ 102 ALL MOTOR GSR
Old Oct 2, 2002 | 04:27 PM
stupidfast's Avatar
Default Re: What size slick for my set up... Please (skunked)
i also recommend 20x8x14in mt slicks.. they are great for anything under 200whp..
Old Oct 2, 2002 | 04:46 PM
ALLMOTOR18's Avatar
Default Re: What size slick for my set up... Please (stupidfast69)
yeah, both 22x8x15 and 20x8x14 will work....
i used the 22x8x15... they worked well...
Old Oct 2, 2002 | 08:33 PM
ExospeedAMcrx's Avatar
Default Re: What size slick for my set up... Please (GSRTypeR)
i'd go with the 22x8x13. your setup is perfect for that size and you wont have to bump up slick size when you get more HP.
Wil
Old Oct 3, 2002 | 04:26 PM
MisterB's Avatar
Default Re: What size slick for my set up... Please (exospeedAMcrx)
i dont think i will ever go over 200whp probably not even over 185 so you think the 22x8x13 would still be the best bet for me? the 20x8x14 may be too small for my set up?
Old Oct 3, 2002 | 05:26 PM
stupidfast's Avatar
id say 20in. it also helps keep your gearing real tight..
Old Oct 3, 2002 | 07:57 PM
you might spin the 20" too easily. thats my opinion, I've used many sizes of slicks and I believe the 22x8x13 is a good enough size for that setup.
I was always running a 20x14x8 on my all motor CRX single cam. was only pushing about 140HP to the wheels the most.
and I was always hesitant in running a 22x8x13 but when I did, I was still running the same MPH but was able to get better 60fts.
and I was running way less HP than you are.
Go with the 22x8 at least.
either or, I do carry both if you are interested.
Wil
Old Oct 3, 2002 | 07:58 PM
we are using the 22x8x13 on an LS vtec pushing about 160hp to the wheels right now and it was getting 13.0's
Old Oct 3, 2002 | 08:32 PM
MisterB's Avatar
thanks everyone some good info here i guess ill go with some 22x8x13
exospeedAMcrx-i have some other things i am going to do first but i will hit you up Wil when im ready for the slicks i always see your good prices
uptownspeedstar
Apr 14, 2008 04:08 PM
crazyimport
Apr 13, 2005 06:46 PM
1BstdEf9
Feb 24, 2005 01:46 PM
beedoublejay
Jul 21, 2003 10:26 PM
bluedelsol
Apr 20, 2003 10:01 PM
