Honda S2000 Honda S2000
Looking to make over 650whp on turbo build
Old Jul 21, 2011 | 12:33 AM
SpoolinInk's Avatar
Default Looking to make over 650whp on turbo build
What's going on guys? I'm new to the forum and wanted to get a few opinons on a good built that will offer over 650whp for my s2k. Got the cat a few years back (ap1) with a good amount of miles on it ,added a cheap godspeed t04 turbo kit and blew the engine in no time.lol Since then I've bought a ap2 engine built by InlinePro
Darton Sleeves
Crower Rods
Cp pistons
Arp rod bolts
3mm Head Gasket
Brian Crowler 2mm over sized valves
Complete port and polished head
Everything was balanced and blue printed By InlinePRO
Engine is still crated at the moment but want to get this built together before I return home from Afghanistan.Here is what I have on the shopping list so far..v2 aem,Full Race mani,precision 6262 or Garrett gt40bb,1200cc injectors,44 tial wastegate,BC stage 2 turbo cams,and 255 in-tank.
Old Jul 21, 2011 | 12:50 AM
HondaKyle's Avatar
Default Re: Looking to make over 650whp on turbo build
Chicago? Welcome to the forum!
Can I say a few things?
You dont need the 3mm head gasket. I'm guessing with the build motor you wont with a lower compression. The 3mm head gasket would lower it EVEN lower. The 6262 would be your best bet. The gt40 will be over kill. What injectors? you would be good with some ID1000s. You wont need the cams and I would recommended the full blown dual intake 255s or a bosch 044.
Old Jul 21, 2011 | 10:58 AM
JdmTypeRdc2's Avatar
Yea just like hondakyle said, no need for the head gasket. The Ilp 3mm hg gives nothing but problems and they don't usually last that long, especially with this much power.
I would stick with those injectors because at that power, the duty cycle will be pretty high with the 1000s.
Precision 6262 ball bearing is your best bet. Spools nicely, makes great power, but im still a fan of the garretts over it. I'd go gt3582x if I had the money instead.
No need for cams, at all. The stock ones are great and people have put down great power with them.
A walbro 255 will not be enough, not even close. You will need another one or a a Bosch 044 instead.
After about 550whp the stock fuel system will not be enough either, so I hope you have plans for a return style fuel system.
Old Jul 22, 2011 | 03:23 AM
SpoolinInk's Avatar
Yeah, i'm from Chicago now stationed in Hawaii.I'll have the 3mm hp removed then, i'm pissed I'm not at home to do the work. Know any good tuners in Chicago area? scratch the cams.and Ill probably go with the bosch 044.6262 it is.Thanks
Thanks for the help.Inlinepro s2000 fuel system.
Old Jul 22, 2011 | 01:11 PM
HondaKyle's Avatar
http://www.facebook.com/pages/Pro-Fu...ve/59044266215
Pro Function. Mikey does all the tuning. He has a great amount of experience and knowledge.
Old Jul 26, 2011 | 07:14 PM
fmfkid250's Avatar
Have similar build
Pfab manifold
T3 pte 6765
Stock motor just put down 700
My fuel system in simple
Id1000 intake 255 feeding a inline 044 stock lines until my engine bay
boarding2008
May 24, 2013 04:19 AM
h22nate
May 13, 2011 06:01 AM
adam00
Jan 24, 2009 08:02 PM
suno
Oct 7, 2008 07:36 AM
berb_15
May 14, 2007 07:03 PM
