easy weld
Old Jul 20, 2011 | 06:58 PM
jumpin4abeat's Avatar
Default easy weld
So I came across a weld that seperated and now has a tiny crack in it. I can not weld but was wondering if there is anything that works well. The crack is about 5mm long and letting water into the trunk. Does that JW Weld stuff work well? If not any thing else?
Old Jul 20, 2011 | 07:42 PM
moxynoff111's Avatar
Default Re: easy weld
JB Weld works great. Drill holes and the ends of the crack to prevent it from continuing and use coarse sand paper to clean up the area. Keep an eye on the repair to see if it cracks more. If so it will probably need to be welded.
Old Jul 21, 2011 | 12:57 PM
thanks
DC-2uned
Welding / Fabrication
Jun 27, 2007 09:11 AM
JCracer723
Mar 8, 2007 07:28 PM
Ca$h
Jan 13, 2005 02:22 PM
Type Goch
Sep 26, 2001 06:10 AM
