b18c IM replaced, now car wont idle and CEL! HELP!!!
Old Jul 20, 2011 | 01:51 PM
Steviebix33's Avatar
Default b18c IM replaced, now car wont idle and CEL! HELP!!!
so i just put my SK2 intake manifold back on, and im positive i put all the lines and sensors back to where they are supposed to be... but i went to start my car and it starts and then dies in the same few seconds. the only way to keep it running it to adjust the throttle cable to the point where its holding the TB a bit open so my car sits at about 1k rpm. CEL has been on since i tried to start it the first time, and the idle has a surge to it at some times, that it didnt have before. i need help!! i dont have an obd2 scanner so i havent been able to read the code. any ideas of what this could be from? i thought it was simple plug n play...
Old Jul 20, 2011 | 01:53 PM
B18CivicEJ8's Avatar
Default Re: b18c IM replaced, now car wont idle and CEL! HELP!!!
There's a STICKY at the top of the forum that tells you how to check CEL.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Hoessaygodinez
Feb 1, 2017 01:44 PM
B20 Twin Cam DC2
Dec 19, 2010 01:24 PM
motrayEG6
12
Sep 4, 2009 03:45 PM
D-series ninja
Dec 30, 2005 06:17 PM
ccivic
16
Jan 4, 2005 12:01 PM
