Tirerack are they good guys?
Old Oct 2, 2002 | 11:57 AM
VTECTIME's Avatar
Default Tirerack are they good guys?
Ima be ordering a tire/wheel combo from them. It will be balanced and everything. So i should be able to rip the box open and pump up the jack and slap'em on!
but i have one question. I can use my stock lugs cant I?
Old Oct 2, 2002 | 12:01 PM
Mojo-Jojo's Avatar
Default Re: Tirerack are they good guys? (VTECTIME)
I've heard stories where one or two wheels wasn't balanced quite right, but it only costs like...$10 to take it to a shop and get it balanced.
My set was perfectly balanced though, so it was probably a new guy on a bad day or something.
Pretty much. Just check the tire pressure too, since that can fluctuate during shipping.
Ummm...maybe. Your new rim might need conical lug nuts.
My set came with new nuts, but I used McGard's.
Your's should come with new nuts too, so don't stress it.
Old Oct 2, 2002 | 12:03 PM
mooseknuckle's Avatar
mine came with the hardware useally they come with the lugs.
Old Oct 2, 2002 | 03:05 PM
isotopesope's Avatar
DO NOT use stock lug nuts on aftermarket wheels. the lugs will NOT seat properly. tuner wheels need conical lugs-> \_/. the stock ones are rounded at the bottom. likewise, you should NOT use tuner lugs on stock wheels. don't let people tell you they will be good enough, it is dangerous.
edit: WTF does the title of this thread have to do with your question? are you ordering everything from them? did they tell you you can use stock lugs on aftermarket wheels? if they told you that then they are not good guys...
[Modified by isotopesope, 5:09 PM 10/2/2002]
Old Oct 2, 2002 | 07:49 PM
VTECTIME's Avatar
Default Re: Tirerack are they good guys? (isotopesope)
no they didnt tell me that. Anywho will they send those conicals to me with my wheels and tires
Old Oct 2, 2002 | 08:02 PM
MrTodd's Avatar
My brother got some a Borbet Rim/Tire package from them. They're really good with their stuff - don't worry about which lugnuts you'll need, because they send you all of the parts required to put your new wheels on.
If it needs new lugnuts, they'll send 'em with the rims.
Old Oct 2, 2002 | 08:06 PM
CrotchRocket's Avatar
Default Re: Tirerack are they good guys? (MrTodd)
I just placed an order with this company for a set of tires. I'll let you know how long the waiting process is when I get my order.
Old Oct 2, 2002 | 08:13 PM
OG LL C's Avatar
New User
Default Re: Tirerack are they good guys? (CrotchRocket)
I had absolutely no problems from http://www.tirerack.com
My wheels and tires made it to my house in 2 days after I ordered them. No scratches and everything was mounted and balanced perfectly. My SSR center caps were on back order and they shipped me out a set as soon as they had them stocked.
About a month later I blew out the side wall on my Khumo (sharp rock) and they next day'd me a replacement for half off their price even though my tire warrenty didnt cover the accident.
Old Oct 2, 2002 | 10:02 PM
creasian's Avatar
never knew that about lugz, anybody got some for sale?
nenetech
Mar 30, 2014 08:55 AM
AznMTboy
May 19, 2011 12:19 PM
inaety
Apr 27, 2009 06:38 PM
genetsang
Apr 21, 2008 06:52 PM
mymeatb18"
Nov 3, 2006 09:05 PM
