95 Accord Abs problem!!!!!
Hi i have a 95 honda accord, which i just replaced the abs unit i bleed all of the brakes, but the light still comes after a min or so. Nothng comes out of the bleeder value on the abs unit is this the problem?? Also the code I'm getting is code 1 ( pump overrun)
fill the abs resivor until max level. place a hose over the nipple on the abs pump put hose in a clean clear bottle partially full of fresh brake fluid. have a helper start the car. when the abs pump starts to run loosen the bleeder valve under the nipple with a flare nut wrench. when i did mine some nasty stuff came out. close valve. refill resivor and repeat as many times as nessecary. it worked for mine
