97 gsr ls/vtec but....no vtec WTF!!!
Old Jul 19, 2011 | 01:58 PM
sscivicsi's Avatar
Default 97 gsr ls/vtec but....no vtec WTF!!!
97 gsr chassis
99 ls shortblock
99 civic si head
boomslang jumper harness
chipped p28 on crome (works in my buddys car too)
brand new oem oil pump
new std size bearings (rod, main, and thrust washers)
black works oil sandwich with -4 line feeding the head
oil galley in head has been tapped and plugged (no i didnt drill to far either)
vtec soleniod is working properly, even installed it on my buddys car and it works on his just fine.
has 70 psi of oil pressure when cold and 60ish when hot
NO cels for solenoid or any of the vtec function
what do i check next??
Old Jul 19, 2011 | 03:53 PM
92shade's Avatar
Default Re: 97 gsr ls/vtec but....no vtec WTF!!!
head untouched? been worked on before/ taken apart
Old Jul 19, 2011 | 06:26 PM
virgineg6's Avatar
You should swap the engine into your buddies car next lol jk
Old Jul 19, 2011 | 08:04 PM
ekjdm89's Avatar
you think your vtec solenoid is bad, have you checked the vtec gaskets to see if they are clean?
Old Jul 19, 2011 | 11:21 PM
NotAJDMFanBoy's Avatar
Oil pressure switch grounded correctly? Is vtec enabled in the computer? Have plenty of oil? how do you know it's not engaging? It shouldn't feel like it's kicking in, it should just sound a little louder.
Old Jul 21, 2011 | 01:35 PM
sscivicsi's Avatar
will you help?? lol
already swapped from my buddys car works fine, and yes the screen was clean as a whistle!
harness is stock with NO check engine lights.
ecu can be swapped to my buddys car and visa versa, still is the same.
i know its not engaging when there is lack of exhaust note change, lack of power in the upper end rpms and i can unplug the vtec solenoid and it runs the same with it unplugged.
i am returning the motor to the person i bought it from and getting the full refund. tired of messing with it!
Old Jul 21, 2011 | 01:46 PM
White_EK_Hatch's Avatar
Try to find an oil pressure gauge to make sure the Vtec solenoid is getting enough oil pressure to engage it.
Old Jul 21, 2011 | 02:01 PM
mike:'s Avatar
Have you tried swapping speed sensors
Old Jul 22, 2011 | 07:32 AM
kuhwahh's Avatar
since it's stock harness, is it the ls one you had, or a vtec harness?
Old Jul 22, 2011 | 09:13 AM
jdmem12000's Avatar
make sure you have a vtec harness. i dnt think it will work with ls harness
Old Jul 22, 2011 | 10:10 AM
kuhwahh's Avatar
It'll work, you just gotta wire the vtec. Sometimes people pin it wrong or the connection is bad.
Old Jul 23, 2011 | 08:18 AM
sscivicsi's Avatar
oil pressure at head is 80 psi at 4500.
when i manually give the vtec solenoid 12v (from a wire directly to the battery)
the oil pressure gauge doesnt even move, yet i still have 80 psi!
wont matter, i have that disabled via crome
it is a stock harness, and it is the correct gsr harness
robert691
Feb 23, 2008 11:48 AM
B18c1turboedEK
Jun 6, 2007 10:07 AM
lsvtec1.9lcrx
17
Dec 15, 2005 04:47 PM
mrbsponge
Sep 25, 2004 04:42 AM
highcomp
Feb 9, 2004 12:32 AM
