Spoon lowering springs--What is the spring rate?
Old Oct 2, 2002 | 11:36 AM
WAFFLES's Avatar
Default Spoon lowering springs--What is the spring rate?
How much do they drop the car and what is the spring rate? Two questions in one...
Thanks in advance to those who know.
Old Oct 2, 2002 | 11:40 AM
BlueR's Avatar
Default Re: Spoon lowering springs--What is the spring rate? (WAFFLES)
6.5f/5.5r kg/mm
-20mm
Old Oct 2, 2002 | 11:47 AM
WAFFLES's Avatar
Default Re: Spoon lowering springs--What is the spring rate? (BlueR)
thank you
BTW...whats the conversion to lbs/in. ?
[Modified by WAFFLES, 2:52 PM 10/2/2002]
Old Oct 2, 2002 | 12:35 PM
Tweakmeister's Avatar
moreso...how do these compare to other springs?
Old Oct 2, 2002 | 01:56 PM
yoshi234's Avatar
I shoot brides
Default Re: Spoon lowering springs--What is the spring rate? (Tweakmeister)
check out Mike's (aka EleanoR) at:
https://honda-tech.com/zerothread?id=263341
Old Oct 2, 2002 | 02:05 PM
SurferX's Avatar
Aren't Spoon springs progressive rate? What's the range?
Old Oct 2, 2002 | 02:13 PM
Default Re: Spoon lowering springs--What is the spring rate? (yoshi234)
yoshi...if you were local I'd send over some cookies and a phone book
Old Oct 4, 2002 | 07:01 AM
WAFFLES's Avatar
hahaha
yeah thanks yoshi...I'm convinced now....these will be on my ride very shortly!
BlueR's Avatar
Default Re: Spoon lowering springs--What is the spring rate? (SurferX)
edit: they sell both
[Modified by BlueR, 11:48 AM 10/4/2002]
Old Oct 4, 2002 | 07:34 AM
SurferX's Avatar
Why do they say so on their website then? The pics look like they are progressive for sure.
http://www.spoon.jp/eng/products/lineup/lineup_1.html
I assume we aren't talking about the customizable straight spring right?
Old Oct 4, 2002 | 07:49 AM
BlueR's Avatar
sorry...edited my post
Old Oct 4, 2002 | 09:53 AM
ITR1069's Avatar
New User
I think the conversion is kg/mm x 55.88 = lb/in.
HTH
Old Oct 4, 2002 | 05:32 PM
SurferX's Avatar
The lowest straight spring Spoon lists is 8 kg/mm. If the springs are 6.5/5.5 then it seems they could only be the progressive. Or are there more that Spoon doesn't list?
Old Oct 4, 2002 | 09:42 PM
Reid's Avatar
Global Moderator
There is only one set of progessive springs. As stated the spring rate is 6.5/5.5.
The linear rate, straight springs are meant to be used with their adjustable damper kit.
Old Oct 4, 2002 | 09:49 PM
SurferX's Avatar
Default Re: Spoon lowering springs--What is the spring rate? (Reid)
Thanks, I figured they were progressive. I was wondering if anyone knew the spring rate range, as 6.5f/5.5r I'm assuming are the maximum spring rate values.
Old Oct 4, 2002 | 10:00 PM
Reid's Avatar
Global Moderator
Oddly enough those are the only numbers printed in the catalog.
I would have thought they'd give the range also.
wifesaynogo
Honda S2000
22
Mar 7, 2007 12:50 PM
S@nt0s
Honda S2000
46
Jan 21, 2007 10:06 AM
speedevo
Apr 27, 2003 09:35 PM
chameleon
Jan 25, 2003 01:50 PM
01-1293
May 16, 2002 11:06 PM
