88 CRX upgrade...
Old Oct 2, 2002 | 11:34 AM
CW-ITR-329's Avatar
Default 88 CRX upgrade...
Hey all, I bought a 88 crx shell and am working on it little by little. First thing I'm doing is suspension and brakes. WHat is the best settup I can go with that is relatively good priced?
Is there any sites people have put up documenting their brake upgrades?(like rear disk stc..)
Thanks,
Ryan
Old Oct 2, 2002 | 11:47 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: 88 CRX upgrade... (CW-ITR-329)
koni full coilover setup
Old Oct 2, 2002 | 12:13 PM
keithv's Avatar
Default Re: 88 CRX upgrade... (MugenHonda)
koni yellows and ground controls for the suspension.
get really good pads (hawk, axxis ultimates, etc.) and good fluid (ate super blue) for your brakes.
Old Oct 2, 2002 | 12:14 PM
raene's Avatar
Are you sticking with the '88 suspension, or upgrading to the rear disc setup? Upgrading also gives you more parts support; it's kind of hard to find rear suspension goodies for an '88 (trust me, I know)
Oh, BTW, I use KVR cross-drilled rotors, KVR carbon-fibre pads and ATE Super Blue fluid... the pedal is much harder than my brother's stock setup (before he wrecked the car ).
[Modified by raene, 1:15 PM 10/2/2002]
Old Oct 2, 2002 | 01:22 PM
CW-ITR-329's Avatar
Default Re: 88 CRX upgrade... (raene)
I am definately wanting to upgrade to rear disk, thats what I was mainly asking. Any sites that show this? Also, I hear the 88 LCA is somewhat like the Type-r. Can I put type-r suspension on this car? Thanks, Ryan
Old Oct 2, 2002 | 05:49 PM
csp88crx's Avatar
Default Re: 88 CRX upgrade... (ridge racer 2)
If you want to use the Koni yellows that are adjustable while ON the car you need to swap to the 90+ LCA's and get the 90+ Konis (part 8041-1153 Sport).
The adjustable Koni's that are available for the 88 model are adjustable but need to be removed to be adjusted.
I think partz.com had the best price on the LCA's, $120.
[Modified by csp88crx, 9:50 PM 10/2/2002]
[Modified by csp88crx, 9:51 PM 10/2/2002]
Old Oct 3, 2002 | 03:01 AM
keithv's Avatar
Default Re: 88 CRX upgrade... (csp88crx)
this is good info. i switched my 89 lcas to 88 and bought the konis for the 88 application. 1 year later i switched back to 89+ lcas and bought the externally adjustable konis...
i bought used LCAs from someone off this board for $25. buy used ones!
Old Oct 3, 2002 | 11:35 AM
mlmf's Avatar
Default Re: 88 CRX upgrade... (breaka_1_9)
I have a 91 Si that I wrecked and just bought a 88 DX to swap everything over from the Si. The rear suspension is a piece of cake. It took about 2 hours total time to do it. Find a wrecked Si and get the rear suspension and do that for the swap. As for breaking power and a B16, it would be a good idea to upgrade the front brakes to compensate for the extra weight in the front.
happy!
Mar 3, 2005 07:03 PM
Acura_I-RS
Sep 29, 2003 03:16 PM
SteveeeO
16
Jan 22, 2003 01:31 PM
nyer1
Dec 14, 2001 06:26 AM
Twainturbo
Nov 26, 2001 09:07 AM
