Dyno-jet/et/mph Qs
Old Jul 19, 2011 | 08:29 AM
LS/V-T's Avatar
Icon2 Dyno-jet/et/mph Qs
I recently Dynoed my car to make a few changes with air fuel and timing..
The dyno I used is a dynojet and with the poor tune I currently have I only made 166whp and 130wtq @ 104F and 8% humidity
My question is does this time slip look like it should be making these numbers in a stock trim 1994 cx hatch with a bseries? I've never weighed the car or I'd give you the weight..
I know I need to better my driving but that's not what this post is about..
Old Jul 19, 2011 | 09:15 AM
boosted92snatch's Avatar
Default Re: Dyno-jet/et/mph Qs
Well i had a 92 si hatch with a gsr in it intake manifold header and chipped ecu..right pretty much exactly what u ran mine dynoed at 167whp dont remember the torque but with a good driver thats what **** should run.
Old Jul 19, 2011 | 11:29 AM
LS/V-T's Avatar
I am really curious to what my 1/4m et and mph would be.. Too far of a drive for me to go at the moment.
Anybody have comparible timeslips with a 1/4m time? Please share of so.. Either post your slip or time/mph. Thanks
Old Jul 19, 2011 | 11:39 AM
Honda Bull's Avatar
I would expect it to have just a hair more power to trap 81 mph in the 1/8th, but I also don't know the weight of the car, and dyno numbers are merely numbers - they are for measuring changes on the same dyno, not for comparing dyno to dyno. LOL
Old Jul 19, 2011 | 12:00 PM
LS/V-T's Avatar
The car is out of tune and has been since the timeslip and the dyno pull. The airfuel before vtec is right at 13.1:1 and goes down to 12.8:1 in vtec..
Here's one of the dyno graphs
I'm not happy with the tune it has and I will be assessing that issue soon. I'm just curious as to what the car will do on motor before we start playing with nitrous.. I guess I can say I'm pleased with it since the motor was built for boost.
Old Jul 19, 2011 | 12:17 PM
LS/V-T's Avatar
Just in case any of you were wondering what I'm working with..
1994 cx hatch full interior, 9.5:1 Ls/vtec w/gsr transmission, 205/50-15 falkin azenis.
•B18a1 Block
•84.5mm Darton MID Sleeves
•Shaved and Balanced LS Crank 34lbs to 30lbs
•Eagle H Beam Rods / ARP Bolts
•JE Forged Pistons low comp
•GoldenEagle Main Girdle
•ARP Head studs
•P72 GSR Head
•Skunk2 Forged Valves
•Skunk2 Springs / Titaium Retainers
•98 ITR Cams
•GoldenEagle Adjustru Cam Gears
•Edelbrock Victor X Intake Manifold
•Edelbrock 65mm Throttlebody
As of right now using an oem itr exhaust manifold with a 3" cat-back..
Old Jul 19, 2011 | 02:17 PM
welfarepc's Avatar
im trapping 76mph and running 8.9's with 130whp in a 2200lb car. hope that helps ya.
Old Jul 19, 2011 | 02:31 PM
Well the car i had in the post up top went 13.9@100
The Jacko
Aug 27, 2006 10:34 AM
Fab-Works
17
Jan 25, 2004 03:12 PM
B18C5-EH2
Oct 23, 2003 09:40 AM
Hondasaurs
Jul 4, 2003 11:42 AM
dwn-shift
Feb 17, 2003 03:10 PM
