rear wheels collect alot more durt/dust then the front
Old Jul 19, 2011 | 07:28 AM
send2artem's Avatar
Default rear wheels collect alot more durt/dust then the front
ive got a 97 civic with rota gt3 rims i washed my car like a month ago and as i was driving though the days i noticed that my back rims were a lil more dirty then the front.
about two wheels passed and i started to notice even a bigger difference
now its been a month and my front rims look like they have just been washed
and the back ones looks like they haven't been washed in 5 years...
what could this be? i have disk brakes all around
i changed all brake pads like 2 months ago
any thoughts please let me know.
Old Jul 19, 2011 | 07:30 AM
FTNW's Avatar
Default Re: rear wheels collect alot more durt/dust then the front
clean your wheel wells and under your chassis
Old Jul 19, 2011 | 07:31 AM
grumblemarc's Avatar
The Grumpiest
What brand pads?
alphalanos's Avatar
im guessing you have low dust pads in front and just regular in back
Old Jul 19, 2011 | 07:35 AM
send2artem's Avatar
what are some good low dust pads for rear anyone?
im running integra disks all around.
Old Jul 19, 2011 | 07:37 AM
FTNW's Avatar
The back ones shouldnt be makiing any dust unless your ripping the ebrake all the time.. am i wrong ?
what color is the dirt on the wheels when they get dirty ?
Old Jul 19, 2011 | 07:38 AM
The Grumpiest
Akebono.
Old Jul 19, 2011 | 07:41 AM
send2artem's Avatar
rims just get like a black grey color but the front ones have barely any dust can barely tell
Old Jul 19, 2011 | 07:43 AM
send2artem's Avatar
i only use e brake for parking and thats it i dont do any crazy ****. after all its not like my car was meant to drift
Old Jul 19, 2011 | 07:49 AM
The Grumpiest
What does that have to do with brake dust?
Old Jul 19, 2011 | 08:21 AM
send2artem's Avatar
because i have heard people say that if you have drum brakes rear wheels dont get as dusty
Old Jul 19, 2011 | 08:27 AM
The Grumpiest
What does the e-brake and drifting have to do with brake dust? I'm not following your logic. Get a set of pads that produce less dust than the ones you have now or wash your rims more often. This one isn't rocket science.
Old Jul 19, 2011 | 08:34 AM
send2artem's Avatar
i said that i dont use my ebrake like an idiot because FTNW thought that i do
and i said that its not like my car was meant for drifting do you get it?
Old Jul 19, 2011 | 08:54 AM
The Grumpiest
No.
Brake dust comes from brake pads. Change the pads or wash your car more often.
Old Jul 19, 2011 | 08:55 AM
Gustav129's Avatar
That's what it has to do with it.....
Old Jul 19, 2011 | 08:57 AM
The Grumpiest
And what does it have to do with it if the OP doesn't "rip" the ebrake? Nothing.
Old Jul 19, 2011 | 09:18 AM
send2artem's Avatar
any one know any good low dust pads
Old Jul 19, 2011 | 09:25 AM
The Grumpiest
I already told you. Akebono.
Old Jul 19, 2011 | 09:27 AM
send2artem's Avatar
oh sorry didnt see thanks
Old Jul 19, 2011 | 09:30 AM
FTNW's Avatar
i was just saying that because some one said something about low dust pads in the back, but it shouldnt matter unless your pulling the ebrake while your driving. i wasnt saying the i think he does that
Old Jul 19, 2011 | 10:17 AM
NOFX's Avatar
H-T White Ops
Most of your braking is done up front, and in turn, those wheels usually get significantly dirtier.
So, if it's not due to pad selection, I'd wonder why if the fronts aren't doing as much work as the rears for some reason. Do you notice you have poor braking performance?
Old Jul 19, 2011 | 10:31 AM
send2artem's Avatar
brakes feel fine but a lil weak could it be because I have an h22?
Old Jul 19, 2011 | 10:49 AM
DSMAddicted's Avatar
Usually Ceramic-based brake pads produce less brake dust. Most major brake pad makers offer "ceramic" pad versions and advertise less brake dust with them. It's possible that you have a compound that produces less dust in the front, which is entirely possible if you invested in more expensive pads for the front.
Also... I might be way off here, but I believe a bad proportioning valve might be causing an imbalance between front and rear braking, which could be linked to unusually high wear/dust in the rear.
Old Jul 19, 2011 | 11:17 AM
Sol Noir's Avatar
My wheels have been doing this as well, but the front are dirtier. Also, my front brakes are also due for a change. I have the pads, but have yet to put them on cause I'd rather not deal with the heat. Hah
Old Jul 19, 2011 | 01:47 PM
FTNW's Avatar
That is normal
Just change them lol it takes like 20 minutes
