rear wheels collect alot more durt/dust then the front
ive got a 97 civic with rota gt3 rims i washed my car like a month ago and as i was driving though the days i noticed that my back rims were a lil more dirty then the front.
about two wheels passed and i started to notice even a bigger difference
now its been a month and my front rims look like they have just been washed
and the back ones looks like they haven't been washed in 5 years...
what could this be? i have disk brakes all around
i changed all brake pads like 2 months ago
any thoughts please let me know.
Re: rear wheels collect alot more durt/dust then the front
The back ones shouldnt be makiing any dust unless your ripping the ebrake all the time.. am i wrong ?
what color is the dirt on the wheels when they get dirty ?
i only use e brake for parking and thats it i dont do any crazy ****. after all its not like my car was meant to drift
The Grumpiest
What does the e-brake and drifting have to do with brake dust? I'm not following your logic. Get a set of pads that produce less dust than the ones you have now or wash your rims more often. This one isn't rocket science.
i said that i dont use my ebrake like an idiot because FTNW thought that i do
and i said that its not like my car was meant for drifting do you get it?
i was just saying that because some one said something about low dust pads in the back, but it shouldnt matter unless your pulling the ebrake while your driving. i wasnt saying the i think he does that
H-T White Ops
Most of your braking is done up front, and in turn, those wheels usually get significantly dirtier.
So, if it's not due to pad selection, I'd wonder why if the fronts aren't doing as much work as the rears for some reason. Do you notice you have poor braking performance?
Usually Ceramic-based brake pads produce less brake dust. Most major brake pad makers offer "ceramic" pad versions and advertise less brake dust with them. It's possible that you have a compound that produces less dust in the front, which is entirely possible if you invested in more expensive pads for the front.
Also... I might be way off here, but I believe a bad proportioning valve might be causing an imbalance between front and rear braking, which could be linked to unusually high wear/dust in the rear.
My wheels have been doing this as well, but the front are dirtier. Also, my front brakes are also due for a change. I have the pads, but have yet to put them on cause I'd rather not deal with the heat. Hah
