Anybody ever narrow aluminum wheels?
Old Jul 18, 2011 | 09:22 PM
55superbeetle's Avatar
Default Anybody ever narrow aluminum wheels?
I have had it done before by a local wheel shop but the guy retired and so did the shop. I can have a machine shop cut them and maybe put a index lip to make sure they stay true. The real question is what filler rod do I use and would heat treating be necessary. They are just a cheap cast wheel but I really want to make these fit my car. The shop that did a set for me before seemed pretty low tech so I dont think there was any heat treating, I know that doesnt mean it was right but I never had a problem either.
Another guy that did it to show i'm not on crack
http://66.154.44.164/forum/showthread.php?t=216215
I just need to narrow the fronts, they rub the strut tube but would fit perfect if they were an inch narrower.
Old Jul 18, 2011 | 10:41 PM
FabChild's Avatar
Default Re: Anybody ever narrow aluminum wheels?
I imagine ER4043 would be the filler to use. I've repaired rims with it before.
Old Jul 19, 2011 | 05:35 AM
914Racer's Avatar
It would be a good idea to anneal and then heat treat the wheel after welding. You are putting a lot of heat into the material. I imagine you will have to have the wheel trued on a lathe once you are done welding. Seems to me like a lot of work.
Old Jul 19, 2011 | 06:21 AM
megomaniac's Avatar
run the next size skinnier tire, thin wheel spacers..
Old Jul 19, 2011 | 09:03 AM
HellaFab's Avatar
Buy new rotas
Old Jul 19, 2011 | 09:23 AM
CRMB's Avatar
OG Fabricator
It would likely cost more then wheel is worth to have it annealed and solution heat treated outside of the machining and whatever else you are planning to do.
Old Jul 19, 2011 | 07:59 PM
Think I'm just going to send them to this guy. I scored the wheels for free so 150 a wheel isn't going to hurt too much. At least if they break and I die it wont be my fault!
http://www.ericvaughnmachine.com/Services.html
Old Jul 20, 2011 | 01:02 PM
TinyT's Avatar
lol what is wrong with you. sell them and buy the right wheels.
Old Aug 2, 2011 | 10:57 PM
jaodesign's Avatar
LOL kellys' is closed now? i'm pretty sure they just cut and added or removed material from the wheel. i like to describe that shop as the dark ages of wheel repair. but they used to be really good!
i would do it the same way those American Racings where done... seems like the best way to keep them true.
BTW i still have a bright green 242 around here somewhere... did you ever get your 55 on the road?
EFOSV.
Nov 11, 2011 06:16 PM
mynameizstitch
Northern California
14
Sep 9, 2009 12:16 PM
ChuckNorris
Apr 2, 2009 04:57 AM
importdude2000
Jan 9, 2007 01:47 PM
Kellindal
Jul 24, 2003 10:38 PM
