Where to find the ball tip screw for rear Hatch lift
I purchase the Monroe MAXLift for my CRX rear hatch but they didn't provide the ball tip stud... The upper ball stud is OEM so no worry but the lower lift support is held by a 14mm bolt. So I need to replace the bolt with a ball stud because the new shock lift has the ball insert on each end. The Monroe didn't give me any aftermarket ball stud to replace it with, so does anyone know where to get the lower ball stud? I have search many places but have no luck.....
Upper ball stud is a 10mm ball with 8mm thread but the lower bolt has a 10mm thread so i cannot replace it with another upper ball stud...
85269-SH3-003 STUD, BALL
$3.84 at Majestic Honda
http://www.hondaautomotiveparts.com/...cgry5=TAILGATE
#29 in the diagram
#29 in the diagram
#29 in the diagram
#29 in the diagram
Some one said they purchase it at NAPA so I'll go see it tomorrow.
Basically the upper ball stud is a 10mm Ball with 8mm thread and the lower ball stud is a 10mm ball with 10mm thread.
now that i think of it. you have the wrong lift support. check it out these are the ones i have for my crx. only the part on the hatch is the ball tip, and the part on the chassis is a normal bolt.
The lift support by itself is the correct size. I just need the ball stud which is usually provided with the kit like the sample picture but it wasn't... So I'm just looking for a place that sells the ball stud with metric 10M thread...
tangerinebeast
Aug 18, 2018 05:09 AM
dtran002
Jul 15, 2010 07:13 PM
vrrodri
Jun 9, 2007 12:38 PM
tangerinebeast
Jan 18, 2006 05:45 PM
LX4CYL
16
Feb 13, 2005 03:12 PM
