Grinding problem b18c
Ok, I have a 93 hatch eg with a stock b18c1... When I turn the car to "on" I am getting aloud grinding noise... Sounds like its metal on metal and It happens in nuetrul or in gear. I had to drive it a block home and it would grind in any gear than go away for a second, I turned the car off and let it sit and it would not do it again when I turned the key to on, but after two min it would do it again... If you need more info just let me know.... Thanks for any help guys
Turn the car on with the hood open and try to find out where the noise is coming from. Check the bolts on the alternator. The nut on my alternator bracket stripped off so every time I turned the car on it, it would screech for a few seconds then go away. I pulled the alt belt off and the noise was gone.
h0ndaSi
Honda Civic (2006 - 2015)
13
Oct 30, 2012 04:56 PM
