Recharge A/C with PROPANE
You can and you can't. HVAC or AC systems can use propane as a refrigerant just like r-12 or r134. Propane refrigerant is called r-290a but the stuff you get from the BBQ grill is the NOT same grade and has impurities like water, oxygen, and other grim.
I wouldn't recommend using it because you have to play with the charge amount, get the right superheats and Hi and low end pressures.
Draggin99Si
Dec 29, 2006 05:36 PM
2002, ac, accord, air, auto, car, charge, charging, conditioner, conditioning, honda, odyssey, propane, putting, recharge, recharging, refrigerant
