Having trouble pinning ECU *HELP*
I have a 95 Civic EX coupe that I just swapped a jdm h22a into. The swap is all but finished except for re-pinning the P13 ECU. For some reason I can seem to get the female pins on the end of the wires Im adding to fit into the grey plastic plugs that plug into the ECU, is there a trick to this? Also how do you remove the female pins from the grey plugs? I noticed there are 2 different size male ends on the P13, do you remove both of those female pins from the plug the same way? Any help would be great.
tkda
Feb 19, 2009 04:23 PM
