del sol type r swap wiring harness
Old Jul 17, 2011 | 09:59 AM
93delsolh22's Avatar
Default del sol type r swap wiring harness
i have a 93 del sol s 5 spd d16y8 is what it had in it i have a b18c5 motor and tranny who has a plug in harness for the swap or do i have to have one made
Old Jul 17, 2011 | 10:05 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: del sol type r swap wiring harness
What harness are you using now? How is VTEC hooked up? What distributor does the Y8 using now? What ECU will you be using?
Old Jul 17, 2011 | 10:07 AM
well my type r was just hit by a jeep motor tranny computer hondata and wiring harness is comin out of the integra the del sol is just a shell
Old Jul 17, 2011 | 10:32 AM
94EG8's Avatar
Seagull Management
If you're pulling the swap out of an actual USDM ITR use the ITR harness, you'll need to run the 2 wires for vtec from the shock tower plug on the passenger's side back to the ECU. Run a chipped and tuned OBD1 ECU (which it sounds like you have anyway)
Old Jul 17, 2011 | 11:38 AM
Red_Army's Avatar
whyd you swap in a d16y8? just curious.
otherwise do whats written above.
Old Jul 17, 2011 | 01:13 PM
NotAJDMFanBoy's Avatar
It sounds like the Del Sol was OBD2. These were rare, but they did exist. They came with an OBD2 P28. Depending what year Type R you had would determine what harness.
The safe bet is to say to use the original harness. You'll already have the VTEC and knock sensor wiring. You may have to pull the cover off the spark plug wires (that plastic cover thing) and put some loom over it, but it should fit that way, especially if you run the wiring through the #1 and #2 intake runners (what I had to do on my GSR motor with ITR style intake using a D16Z6 harness). Both sets of injectors will work, they're the same size dimensionally and in flow. The only potential issue is in alternator and distributor wiring in which the OBD1 and OBD2 are different.
Could you post pictures of the Type R? Maybe it could be fixed? Otherwise, there's a LOT of parts you could use. Front, rear suspension, brakes, cluster, seats....
Old Jul 17, 2011 | 06:13 PM
94EG8's Avatar
Seagull Management
No actually it doesn't, it's a '93 (OBD1) and an S model (D15B7 or D16Y7 depending on the year) so it sounds a lot more like it's a swapped Del Sol.
It's much easier to just use the ITR engine harness, seeing as how it simply plugs in at the OBD1 shock tower plugs, no modifications necessary, plug and play.
thatdelsol
21
May 7, 2018 06:18 PM
a93and07si
Oct 15, 2008 02:00 PM
digital sol
Jun 29, 2006 12:32 PM
brizjuan
May 1, 2004 09:23 PM
JDM CRX
Jan 14, 2003 12:19 AM
