Need help Timing a6!
Old Jul 17, 2011 | 08:10 AM
tpnorth's Avatar
Default Need help Timing a6!
So my timing belt snapped and im hoping for the best but expecting the worse.I Got everything apart and i turned the head to tdc"up" and then i turned the crank to the dash on the timing cover.Did i do that correct? Every thread i found always tells you to mark the old belt and **** but my old belt is in two peices.
Old Jul 17, 2011 | 08:30 AM
k20rex's Avatar
Default Re: Need help Timing a6!
just line the marks up, the cam will have marks on the sides and top, i think there is 4 marks on the the crank pulley 3 next to each other one about a inch away, if you are not sure what mark to use pull the spark plug out of the number one and stick a screw driver down to insure you are on tdc
Old Jul 17, 2011 | 10:44 AM
SuicideError's Avatar
This is all I could find as for timing on the a6. hope it helps.
Old Jul 17, 2011 | 05:18 PM
1990edsedan's Avatar
I think that cam timing applies to the ZC. If you have a usdm si (D16A6) the cam timing is different.
Try here: https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/d16a6-timing-diagrams-2947875/
Both JDM/EDM and USDM are shown..
Old Jul 17, 2011 | 05:46 PM
raffaelli's Avatar
Get the head aligned at TDC by aligning the marks on the cam with the top mating surface of the head like the diagram above shows. Get the #1 piston to TDC by rotating the pulley. Once you have the top and the bottom lined up, put the belt on and tension it like the diagram shows.
To check that you are on the right tooth, turn the engine by hand with a wrench on the pulley bolt. Turn it over 4 complete pulley rotations. Check your marks. If it lines up just like it did when first put the belt on, you have the right tooth.
Then get a timing light on it and adjust the timing.
Old Jul 17, 2011 | 06:19 PM
Try here: https://honda-tech.com/forums/showthread.php?t=2947875
this is from a usdm a6. I got it from alldata.
Old Jul 18, 2011 | 03:56 AM
I would trust Mitchell over Alldata any time.
There is a pointer which is on your bottom inside timing cover. You will have to line up that mark with the timing mark that is in the 7 o'clock position on the the cam pulley. Bottom pulley timing mark has to line up with the pointer just above the tensioner bolt on the bottom timing cover.
Old Jul 18, 2011 | 03:17 PM
thesmogman's Avatar
As for the cam pulley it is the middle circle (4wd) as marked.
For the crank you want to use the white mark. Not the 3 marks.
I just did this awhile ago.
I just used the up mark and the side marks then moved the cam 1 tooth counterclockwise.
I do agree with spinning with a wrench a couple of revolutions and recheck your marks.
Old Jul 18, 2011 | 07:30 PM
raffaelli's Avatar
Not a couple, must be 4. Plus it is tough to disagree with fact!!
flipldls
Jun 6, 2010 08:45 PM
716pro
10
Apr 12, 2009 09:08 PM
Salsa
Feb 28, 2009 11:31 AM
JediKGB
Dec 4, 2005 02:29 PM
Carp
Oct 15, 2001 11:05 AM
