94 accord starting problems
Old Jul 16, 2011 | 08:32 PM
jonathanj1012's Avatar
Default 94 accord starting problems
so the other day i was picking up a friend and while i was stopped in park i was about to put it in drive and the car died put it back in park and it started up and drove just fine for a bit but then some times when i was stopped it would die and now its hard to start up it will only start up when i have my foot on the gas but will stay started and drive fine at around 35 and higher but at low speeds i hear something knocking but when i give it a little gas it goes away i changed the spark plugs about a month ago other then that i have not done anything else to the car if anybody has any ideas or can help i would really appreciate it thanks for any ideas
Old Jul 17, 2011 | 07:58 AM
phootbag's Avatar
Default Re: 94 accord starting problems
Does the engine stumble as it dies or does it quit without hesitation?
Old Jul 18, 2011 | 07:13 AM
the first time it died, it was when i was putting it in to gear, and it just died, then the next time it died, i was at a stop in gear and it was more like a stumble and die and now it wont start with out giving it gas
Old Jul 18, 2011 | 07:25 AM
SQ is the SQUAD's Avatar
possable bad gas/water. try some octane booster and some 93 octane. jump on the rear bumper to shake the car and mix it up real good. happened to me once, this fixed it.
Old Jul 18, 2011 | 03:06 PM
phootbag's Avatar
I bet you're not giving it gas you're giving it air. The symptom could be caused by a sticking IAC valve. Cleaning it can be iffy depending on how thorough you are.
W95civicEXcoupe
25
Sep 29, 2014 05:07 AM
rll2
Jan 7, 2013 08:21 AM
JDM-EJ1
Aug 22, 2005 04:39 AM
KoKreation
Jun 27, 2003 04:24 PM
