Wiring Issues anyones thoughts
Old Jul 16, 2011 | 03:21 PM
TorinRage's Avatar
Default Wiring Issues anyones thoughts
Hello, I bought a shell 1992 teg was at the time a very clean shell but the guy i bought it from hid the the fact the body harness on the car was actually cut.
I bought a 1994 acura Motor from my local junk yard. it is a obd1 motor and the car should be ob0 but the cut the harness up and i am missing some plugs can anyone post a photo of the plugs around your fuse box under the hood from your 94 teg mainly the 3 main plugs and the fuse box its self. or know a good place to find a wiring diagram. I have 40 plus pages of diagrams but non of the colors are not matching up to it
Old Jul 17, 2011 | 09:00 AM
fcm's Avatar
fcm
Old Fart
Default Re: Wiring Issues anyones thoughts
I pick up my 94 Teg from the body shop on Mon. will take pix then. 94
Old Jul 17, 2011 | 03:50 PM
TorinRage's Avatar
thank you man hate when people do **** like this and screw people over that just wanna build
Old Jul 18, 2011 | 06:19 AM
fcm's Avatar
fcm
Old Fart
You may also want to check your local bone yards, unfortunately the closest PicknPull is in Columbus, it has a 92 and a 97, but 162 miles, [one way] is a long way to go in hopes of finding an undamaged harness, but then again evena a "large" harness at PicknPull is only $34.99.
Maybe it would be worth it to make a list of things you need or may need and make a day trip to Columbus, PicknPull parts are pretty cheap... http://www.picknpull.com/part_pricin...=&#partpricing I have a bunch of spare parts for my 94 Teg from my local PicknPull, we have two 93s, I can check for wiring harnesses next time I am there if you want. 94
Old Jul 18, 2011 | 11:59 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Shot us a pic of the ecu plugs, Some da's are obd1
Old Jul 19, 2011 | 05:34 AM
fcm's Avatar
fcm
Old Fart
It was late so I took these...
I will be putting the interior back together on the weekend so i will drop the fuse box for som better pix. 94
Old Jul 19, 2011 | 09:18 AM
el crapitan's Avatar
your 92 is obd1. same as the 94. everything from the new motor should just plug in. that is, after you replace the harness. your diagrams may be for a non obd integra. maybe why you're having trouble matching the wire colors.
i would just replace the engine bay harness, personally.
912fourtysx
Sep 30, 2011 08:40 AM
ELAMINT5
16
Jun 16, 2005 08:26 AM
originalbadbob
May 15, 2004 10:32 AM
Phoenix GSR
Mar 12, 2002 11:45 PM
yokalryder
Jan 14, 2002 08:48 AM
