Suspension & Brakes Theory, alignment, spring rates....
DIY skunk2 pro or blackworks upper ball joint for crx camber kit mod
Old Jul 16, 2011 | 02:25 PM
Wdbjr12345's Avatar
Default DIY skunk2 pro or blackworks upper ball joint for crx camber kit mod
well everyone knows that the skunk2 ball joints on there camber kits die in a short amount of time and i figured i post a diy for making them work since there little different then what skunk2 provides and this mod works for ither the newer pro series ball joints or the blackworks racing ones.
tool list
10mm wrench and socket
14mm wrench
17mm wrench
a BMF hammer
a cutoff wheel
a jack
ok lets get started here is what the brand new ball joint looks like un touched.
you take your cut off wheel and grind the ends off a little bit so it looks like this
then install so they fit like this
then all finished this is the second set ive done and havent had a problem i may install grese fittings in it so they last forever well in a perfect universe
Old Jul 16, 2011 | 03:04 PM
Drive 4 fun's Avatar
Default Re: DIY skunk2 pro or blackworks upper ball joint for crx camber kit mod
Originally Posted by solbrothers
you dont need a camber kit doe
Could want more camber for the track.
Old Jul 16, 2011 | 07:15 PM
GagnarTheUnruly's Avatar
You'll find that most of the things in life we have are things we don't need.
Thanks, OP for the DIY guide -- hopefully it will be useful to someone.
Old Jul 18, 2011 | 06:02 PM
Libertariat's Avatar
Ek Forever y0!
Nice mod OP.
Old Jul 18, 2011 | 10:08 PM
abs0Lut's Avatar
what brand of balljoint is that?
Old Jul 19, 2011 | 08:03 AM
Wdbjr12345's Avatar
Blackworks but this mod will work for the new skunk2 pro ball joints.
vanny_david
Suspension & Brakes
10
Nov 20, 2009 09:39 AM
dc2ls-vtec
Suspension & Brakes
Oct 20, 2009 02:32 PM
codyellis
Aug 5, 2009 08:12 AM
blbvtec
Jun 28, 2003 08:59 PM
Shorty C
14
Jun 15, 2003 09:23 AM
