b20 crx
Old Jul 15, 2011 | 08:11 PM
x91si's Avatar
Default b20 crx
i have a b20z2 swap in my crx just looking for some ideas on what i can do to gain some power. im not trying to go all out just some mild stuff. any input would be greatly appreciated.
ran 14.675@95mph today...
i currently have i/h/e, 9.75lb flywheel, and im running obd0 with a da intake mani.
Old Jul 17, 2011 | 06:17 PM
Jovanni91Da's Avatar
Default Re: b20 crx
ttt im looking for the same info for a b20b
Old Jul 17, 2011 | 06:31 PM
1991civicb16's Avatar
Default Re: b20 crx
Vtec head
Old Jul 17, 2011 | 06:36 PM
Default Re: b20 crx
^^ive been told b16 heads are the best combo for them, but i also heard a straight b20 built for allmotor no Vtec runs really hard
Old Jul 17, 2011 | 06:39 PM
Default Re: b20 crx
Yes B16 Head is the best head for the money. Ive been TOLD that a B16 head on a B20 can run about the same times as a type r swap. Not verified but seems to sound about right if that guy is running 14.6 on a stock B20.
Old Jul 17, 2011 | 06:43 PM
Default Re: b20 crx
yea ive been told that they even beat type r's with no prob built right though, and they said fully built b20 im not sure vtec or not could also be a k killer, a shop out where i am supposively put down 230whp idk if those are accurate numbers but i like how that sounds
Old Jul 17, 2011 | 07:23 PM
KINGVEM^^ED6's Avatar
Default Re: b20 crx
TURBOH
Old Jul 17, 2011 | 07:29 PM
Default Re: b20 crx
i gotta have the walls resleeved there to weak to hold alot of boost and if your gonna boost go for high numbers not hop you can make allmotor
jdmrexx402's Avatar
Default Re: b20 crx
obd1 b18b manifold port to match 70mm tb and 50shot of nawzz
Old Jul 17, 2011 | 07:36 PM
Default Re: b20 crx
obd1 already so im good and i have that many how much for the port and polish?
Old Jul 18, 2011 | 07:55 AM
alex14's Avatar
Default Re: b20 crx
70mm tb will hurt you on an stock NA build. port your intake manifold, get a b16 trans if you dont already have one. convert to obd1 and get it tuned. lighter wheels, remove interior, ect.
Old Jul 18, 2011 | 09:03 AM
el crapitan's Avatar
Default Re: b20 crx
which transmission you running?
Old Jul 23, 2011 | 04:25 PM
x91si's Avatar
Default Re: b20 crx
i just recently did the obd1 mani and im currently running a cable ls trans.
id like to stay straight b20 non-vtec my block is obd2 which means i would have to tap it for vtec, im kind of hesitant about doing that. id really like to get a set of cams but not sure which route i should go. stg1 crower and get new valve springs? just something mild in mind i had... what to do what to do...
Old Jul 23, 2011 | 04:26 PM
x91si's Avatar
Default Re: b20 crx
hows the b20b? i cant remember what they make stock isnt it the same as the z2?
Old Jul 23, 2011 | 04:47 PM
nonvtecD's Avatar
Default Re: b20 crx
Get some shorter gears, cams and valvetrain, get it dynoed, run 13's.
Old Jul 23, 2011 | 07:01 PM
Default Re: b20 crx
Definitely look into a shorter geared tranny. IMO, it deserves just as much attention as the motor itself.
That ls trans is robbing you. Trust me. Id look into that next
Old Jul 23, 2011 | 07:06 PM
x91si's Avatar
Default Re: b20 crx
yea im gonna look into getting a b16 trans ive heard alot of good things about the gearing vs the ls
Old Jul 23, 2011 | 07:16 PM
Default Re: b20 crx
If I were you, I'd have your ls fifth gear set installed in the new trans though. While it's out anyways. Believe me, you'll wish you had for highway cruising
xotic_crx
48
Oct 10, 2007 03:47 PM
KrenzyRyan
25
Apr 12, 2006 08:03 PM
superls92
Jul 9, 2003 06:49 PM
