I'm going to try alcohol injection
Old Oct 2, 2002 | 09:12 AM
senpai's Avatar
Default I'm going to try alcohol injection
I want to construct the ghetto alcohol injection kit for myself. I have my D-series fuel pump sitting in a box. DO you think the pump can handle denatured alcohol injection? Is my pump sufficient or TOO much?
Old Oct 2, 2002 | 09:38 AM
Vanilla Ic3's Avatar
Default Re: I'm going to try alcohol injection (maztur)
After time the alcohol may damage the pump internals, but it should be fine for a while. It's a cheap pump so don't sweat it. How are you planning on setting it up so it fuels only at boost?
Old Oct 2, 2002 | 09:40 AM
VaporTrail's Avatar
New User
you'll need to add a lubricant to the aclhohol mixture so as to not kill pumps every fix minutes.
Old Oct 2, 2002 | 10:38 AM
filetofit
Guest
Posts: n/a
Default Re: I'm going to try alcohol injection (VaporTrail)
What do you add to alcohol to act as a lubricant?
Old Oct 2, 2002 | 10:39 AM
zojirushi's Avatar
Default Re: I'm going to try alcohol injection (filetofit)
ky jelly
j/k
Old Oct 2, 2002 | 10:42 AM
b18bturbo's Avatar
use some redline methanol additive it work great
Old Oct 2, 2002 | 10:49 AM
Finest's Avatar
Default Re: I'm going to try alcohol injection (zojirushi)
ky jelly
j/k
Been experimenting huh?
Old Oct 2, 2002 | 12:17 PM
bruthaboost's Avatar
Default Re: I'm going to try alcohol injection (Vanilla Ic3)
You can use an adjustable map switch and relay
Old Oct 2, 2002 | 12:30 PM
zojirushi's Avatar
Default Re: I'm going to try alcohol injection (Prelude_RCR)
ky jelly
j/k
hahaha
Old Oct 3, 2002 | 05:14 AM
senpai's Avatar
Default Re: I'm going to try alcohol injection (b18bturbo)
Are you talking about this?
But then I'd have to keep on buying Redline's expensive products...Somehow I think that the pump will fail on me.
Anyone know where I can get an adjustable boost pressure switch?
Old Oct 3, 2002 | 05:31 AM
D-X-Factor's Avatar
Use methanol not ethanol and it will not break down the rubber seals in your pump.
Mario
Old Oct 3, 2002 | 08:37 AM
mos's Avatar
mos
Default Re: I'm going to try alcohol injection (D-X-Factor)
I've heard that running the alcohol/methonol as low as 50/50% mixed with distilled water gives the same results as pure alcohol. Maybe someone who has tried different mix ratios can comment on how this works?
Old Oct 3, 2002 | 10:24 AM
senpai's Avatar
Default Re: I'm going to try alcohol injection (mos)
Yea, who actually is running this?
Old Oct 3, 2002 | 01:29 PM
I'm running the SMC alky kit, however I don't have any dyno data. My ecu was throwing a code on dyno day ( I still can't figure out why I don't have oil pressure )
A little advice:
Though it's a PITA, do the trunk mount reservoir. You'll be able to hold much more enthanol and won't have to refill as often. Also Nalgene make great containers for this. I picked up a 2.5+ gallon HDPE one for 47.00.
If you use pure methanol or ethanol, you'll be able to cool the alcohol to -78 C
(-108 F) with dry ice, thus you'll be able to cool the intake charge even more. I need to get a thermocouple and look at the temp drops, but I haven't had time yet.
Old Oct 3, 2002 | 02:36 PM
BigMoose's Avatar
Darn I can't find the reference, but in the last week I "think" I read that a ford F250 fuel pump has all stainless internals and will work with alky. Don't take my memory for gospel, perhaps you could search the net with Ford or F250 and alky and find the reference.
Come to think of it, it was a link off an article on here. Anyone remember it?
Regards,
BigMoose
Old Oct 4, 2002 | 03:37 PM
BigMoose's Avatar
Default Re: I'm going to try alcohol injection (BigMoose)
I found the reference I was looking for the other day. Take a look at http://www.geocities.com/rad87gn/tech/alcohol.html It is by the Buick Grand National Guys, but it provides good theory and practice on alky/water injection and has a list of kit makers at the end.
Regards,
BigMoose
Old Oct 4, 2002 | 03:55 PM
BudaKai's Avatar
You can run up to a 70/30 ratio 70 being alky. I just put some fuel additives as lubrication at 1/2 cup per alky fill. I run it with the stock ef windshield tank and Jrsc pump I got off my friends rail when he switched to Nitromethane. Why is it that everyone thinks Newbies are stupid? I'm not an idiot yet everyone thinks my advice is bad. It works for me after all. Sorry if I just now got my internet hook-up. I just moved to Wisconsin.
[Modified by tzsir, 6:57 PM 10/4/2002]
Old Oct 4, 2002 | 04:49 PM
senpai's Avatar
Default Re: I'm going to try alcohol injection (tzsir)
Hey, I'm from Milwaukee.
Anyways, what did you use as a spray nozzle? NOS?[
[Modified by maztur, 7:49 PM 10/4/2002]
Old Oct 6, 2002 | 02:39 AM
BudaKai's Avatar
I use a 35 shot nozzle from an older domestic kit. I live in kenosha on the north side and where in Mil. are you that's a big city you know.
Old Oct 6, 2002 | 05:25 AM
EKB18BPR3's Avatar
i wouldnt recommand using water at all...ur risking hydro lock
[Modified by dniedacess, 2:26 PM 10/6/2002]
Old Oct 6, 2002 | 09:04 AM
senpai's Avatar
How is the atomization on that? I'm afraid that it doesn't spray it so well...I'm from the WAY north side of Milwaukee, close to Menomonee Falls.
Old Oct 6, 2002 | 09:06 AM
senpai's Avatar
Default Re: I'm going to try alcohol injection (dniedacess)
Not if you're using the correct nozzle. The water will be gone before it hits the TB.
ohsnapzafingcu
Nov 17, 2013 08:20 PM
ahobbs
Feb 23, 2011 11:08 AM
o2flow.net
Jan 11, 2006 11:48 AM
bigedx
Feb 29, 2004 03:43 PM
boostincoupe
Sep 10, 2003 11:51 AM
