96 Accord Power Window
Old Jul 14, 2011 | 07:32 PM
7azhar7's Avatar
Icon2 96 Accord Power Window
There are many things wrong with my windows. First of all the driver side window goes down perfectly but putting back up you have to hold it straight to make it slide up right. Secondly the back drive side windows, master switch can make the back window go down but not back up. Same goes for the front passenger window. I checked fuses under the hood and under the driver side all good. Any suggestions what it could it be?
Old Jul 15, 2011 | 04:53 PM
poorman212's Avatar
Default Re: 96 Accord Power Window
1) Check the guides and reg on the drivers door.
2) Do the individual window switchs (RF, LR, RR) make the windows work? So just the master only goes down....I'm guessing so or the "other" windows would be down with no way to roll them up......test the master switch.
Old Jul 15, 2011 | 07:35 PM
chikin pickle's Avatar
Go down to the hardware store and get some silicon lube. It comes in a spray can with a little straw. Spray it generously all throughout the window track. As the rubber gets old, it dries out and catches the glass on the way up, forcing it off track. Did this one one car where all four windows were off track, and three worked perfectly after that.
They roll up faster too.
Old Jul 17, 2011 | 02:10 PM
7azhar7's Avatar
Took the master switch out did a lil cleaning around it and got the passenger side to work again but not the back driver side. The front driver side window is in between the rubber. just weird that when it goes up its not straight. I might try to lube it and see what happens
bmclean1
Feb 22, 2011 04:42 PM
marks97el
Dec 27, 2010 08:49 AM
damdash
Jun 24, 2009 05:08 PM
92ehatch
Mar 3, 2006 02:49 AM
cosmicjim
Jan 25, 2003 08:36 AM
